Rough start, bad mpg - Ford Powerstroke Diesel Forum
post #1 of 15 Old 02-20-2012, 05:36 PM Thread Starter
Earlier this fall i had new glow plugs/block heater installed. Now that its winter if cranks for almost 30 seconds before it starts, and that's with it plugged in. It cranks for a minute or two, sometimes longer, when not plugged in. I've also never got very good mpg with it either. When i bought it, it had an 8 in lift with 38's on it...but i didn't like it so i sold the lift and tires for a leveling kit and 32 in tires, and still didn't get any better mileage. I also deleted the muffler, cat, and did a complete egr delete and can't seem to get over 12 mpg... is this all related?
2006 King Ranch: Sinister EGR Delete, SCT tuner with Looney tunes, Edge Insight CTS, 5" turbo back exhaust with 6" tip, Bulletproof oil cooler, Updated Stc fitting, S&B intake, Sinister coolant filter, halo projector headlights/tail lights, drilled and slotted rotors, Mad Turbo Werks hybrid turbo
ZachMyers is offline
post #2 of 15 Old 02-20-2012, 06:30 PM
Jaybird093's Avatar
Does it idle rough on start-up? Any smoke?
________________________
2006 F-350 CCLB Lariat
6.0 Powerstroke
6-Speed Manual
5" MBRP Turbo-Back Strait Pipe, 6" tip
'03 Turbo
6.4 Banjos
BLUE Spring
High-Idle Mod
Zoodad
Amsoiled & Rev-X'ed
DieselSite Coolant Filter w/ Cat ELC
295/65/18 Duratracs
Jaybird093 is offline
post #3 of 15 Old 02-20-2012, 07:44 PM Thread Starter
Yes at first start up it idles rough and i get some white smoke... but as soon as it starts up everything smooths out and the exhaust clears up
post #4 of 15 Old 02-21-2012, 05:26 AM
What's your FICM voltage? Under 46V at any time and it needs to be replaced.
2005 - Excursion - Eddie Bauer - 4x4
185amp DC Power Engineering alternator
BPD oil cooler and cold weather package
Updated standpipes and dummy plugs
Edge Insight CTS with fuel pressure
No more STC fitting in the HPOP
Updated fuel pressure spring
Updated turbo oil drain
Updated turbo oil feed
Sinister Coolant Filter
BPD 58V FICM
Dual Batteries
Rotella T6
CAT ELC
The best 6.0 advice I've ever seen...
Fishermedic is offline
post #5 of 15 Old 02-21-2012, 05:45 AM
Unapologetically American
2006PSDSD's Avatar
Quoted: 29 Post(s)
Feedback Score: 4 reviews
I bet your FICM is toast
2006 F350 SOLD
* KMC XD Monsters wrapped in Hankook ATM's
* 08 style mirrors
* 4" TB exhaust
* SCT X2 with Gearhead, PHP and ID tunes
* Edge Insight CTS
* Blue FPR spring
* 6.4 Banjos
* Dfuser coolant filter
* Stage1 MTW turbo
New truck has a Cummins and a handshaker
2006PSDSD is offline
post #6 of 15 Old 02-21-2012, 05:48 AM
War is the answer!
WarChild's Avatar
Quoted: 24 Post(s)
+3 on the FICM
White 04 F350 Lariat SRW/CC/LB/FX4 227,XXX+
Studs/BPD58V FICM Atlas40/BPD oil cooler/waterpump/7.3 fan
Edge insight CTS EGT/Turbo timer/FP SCT with ? Tune
Powermax w/KC billet wheel Warren 175/30%
5-8" MBRP Off Road Turbo Back/harpoon
2" Leveling/33' BFGATKO
ELC/PMM Coolant filter
aFe Stage2/EGR Delete
(Always Faithful) is the motto of the Corps. That Marines have lived up to this motto is proved by the fact that there has never been a mutiny among U.S. Marines.
WarChild is offline
post #7 of 15 Old 02-21-2012, 09:12 AM Thread Starter
When it runs it usually stays around 47.5 and during start up never drops below 46... atleast thats what my edge evolution insight shows
post #8 of 15 Old 02-21-2012, 09:44 AM
War is the answer!
WarChild's Avatar
Quoted: 24 Post(s)
Mine never drops below 48V.
WarChild is offline
post #9 of 15 Old 02-21-2012, 11:21 AM
2006PSDSD's Avatar
Quoted: 29 Post(s)
Mine did the same thing, until one cold day, it was at 36v. I had blueish smoke during warmup, and some rough idles at times. You need to check it at the FICM, during cranking. I have the Edge Insight, and it just doesn't read fast enough to catch it during the short starting procedure
2006 F350 SOLD
* 08 style mirrors
* 4" TB exhaust
* Edge Insight CTS
* Blue FPR spring
* 6.4 Banjos
* Stage1 MTW turbo
post #10 of 15 Old 02-21-2012, 10:43 PM Thread Starter
Ok I plan on doing a load test on my batteries tomorrow, and then doing a voltage test on the ficm...if it does need repaired is it worth it to do 58v upgraded ficm... ficmrepair.com says its a bad idea because a normal ficm gets hot enough just being under the hood...and adding extra volts means for extra stress
