Another Dumb @$$ can't get high idle to work - Ford Powerstroke Diesel Forum
Old 02-19-2012, 12:59 PM
so I'm trying to get a high idle going in my truck, followed the instructions to a tee, connected up-fitter #4(orange-light blue stripe), to the orange PTO wire. used butt connectors and a piece of wire. apply E-brake, manuel trans in neutral. start her up, let her idle for 20 seconds, hit the switch, waited over a minute, nada, truck stays at stock idle. Any ideas what i did wrong?
truck is an 06 with the 6 speed.
Doug
Old 02-19-2012, 02:05 PM
I did the same thing with mine when I first did it, the wire you need on an '05+ is the Pruple/Green Stripe, it's in that same bundle as the PTO wiring. I'll post a step by step write up that I posted on another forum
Old 02-19-2012, 02:35 PM
Feedback Score: 3 reviews
I'm not sure it can be done with a manual shift, unless you buy the external box.
Old 02-19-2012, 02:47 PM
I too was thinking it cant be done with a manual transmission....
Old 02-19-2012, 02:48 PM
Can still be done, mine was easy, I just have to make sure to do a neutral shake before you fire it up since I disabled the switch that makes you have to push the clutch to start it (in preparation for a remote start)
Old 02-19-2012, 02:52 PM
Thank you for the quick replies, and PowerSmoke07 ill go back down to my shop and try the purple/green stripe wire, ill let you know how it goes.
Doug
Old 02-19-2012, 03:07 PM
No, no, no... It CAN be done. You just need the right wire.
Old 02-19-2012, 03:18 PM
so i couldn't wait to go back to the shop, 15 min drive each way. So out comes the trusty multi-tool in the driveway. took all of 30 seconds to switch to the purple/green stripe wire. worked like a charm, i can high idle to my hearts content. a special thank you is in order for PowerStroke07 for pointing me in the right direction.
Doug
Old 02-19-2012, 03:21 PM
I'm learning something new everyday! Thanks
Old 02-19-2012, 03:26 PM
That's why we're on a forum right? To find out little tips and tricks and learn from each other.
