Parts needed for....... Stand pipe upgrades & STC fitting upgrades? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 02-19-2012, 12:21 PM Thread Starter
Dante04SRT's Avatar
Quoted: 2 Post(s)
Feedback Score: 9 reviews
I believe my truck is suffering from a failed o-ring around the stock standpipes.
Aside from the redesigned pipes and plugs, what specific gaskets or extras will I need? I want to order everything and have it waiting so I can tackle the project this coming weekend.
-Brian
2005 F350 6.0 CC/SB Lariat 4x4
EGR Delete
ARP Studs
All updated Ford internals
Edge Insight CTS2
Swamp's 58V FICM
SCT X3
TGC 2.5" Level Kit
Zerex EC-1 ELC
08+ Step Tailgate
08+ All Power Mirrors (Factory Functions, too)
2011 Rear Bumper
B&W Turnover Ball
8oz Stanadyne Performance w/each fillup
Dante04SRT is offline
post #2 of 7 Old 02-19-2012, 12:35 PM
Powerstroke Techie
Quoted: 16 Post(s)
Garage
Feedback Score: 4 reviews
aside from the part numbers which I'm sure someone else will provide a couple tools make the job a little easier
First one is a stubby 12mm gear wrench for the valve cover bolts under the evaporator box. the next one is a Lisle T30 socket for the high pressure rail bolts under the evaporator box. The old stand pipe plugs and dummy plugs are 10mm hex. The new ones are 12mm hex, you will need both sockets for those.
all the rest should come off pretty easily. the heat shield on the back of the HPOP cover has two 8mm bolts that are tricky to get to, an 8mm ratchet wrench is good for these and the 2 hpop cover bolts under the EGR cooler. I always like to take out(or loosen if possible) two of the y-pipe to manifold bolts, one on each side so you can physically push the entire pipe assembly back in order to get the pump cover off easier.
Also the HPOP bolts are T45 so have one of those too
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #3 of 7 Old 02-19-2012, 01:20 PM
Quoted: 14 Post(s)
Kit for dummy plugs and stand pipes (late 04-07):
6E7Z-9A332-B
Includes:
two updated dummy rail plugs
two upated standpipes
one crankcase vent o-ring and
high pressure oil gallery plug
STC Kit (05 and up ONLY)
4C3Z-9B246-F
The Ford 6.0 STC HPOP Fitting Update Kit 4C3Z-9B246-F contains:
* 1 Support Bracket
* 1 Hydraulic Pump Seal Kit
* 1 Branch Tube Adapter - Male
* 1 HPOP Adapter Fitting - Female
* 2 M6 X 35 mm Branch Tube Bolts
* 2 M8 X 60 mm Pump Bolts
* 1 M8 X 45 mm Pump Bolt
Mark
06 F250CC SB FX4 Lariat;ARP studs;OEM gaskets; Banks exhaust;DynaTrac Ball joints;Coolant filter; High-Idle;RACCCV6000;JimmiJammers;Ravelco;SynchroMax trans case;Fumoto valves;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower270AXP;PowerInverter;Rancho7000's; BPD EGR cooler;One-piece HPOP fitting;BilletWaterPump;SCT w/ Matts SRL;ELC Ultra
bismic is online now
post #4 of 7 Old 02-19-2012, 01:36 PM
Powerstroke Techie
Quoted: 16 Post(s)
Garage
does the HPOP connector kit come with turbo hardware? I can't remember..... If not you should get one of those kits too
3C3Z-9T514-AG
-Matt
2015 F-250 XLT 6.7L
post #5 of 7 Old 02-19-2012, 02:25 PM
Quoted: 14 Post(s)
3C3Z-9T514-AG
Mark
post #6 of 7 Old 03-08-2012, 06:00 PM
Im in the process of doing the same repairs. Only thing is that when i changed out an injector a few months ago, i kinda stripped 2 of the T-30 torx bolts holding the oil rail down. 2 questions. First how do i get the off if the are stripped and second, what is the part# of the bolts so i can replace them? Sorry if i hi-jacked the thread and thanks in advance for any info.
Turb0 is offline
post #7 of 7 Old 03-08-2012, 06:18 PM
Powerstroke Techie
Quoted: 16 Post(s)
Garage
W301383 are the rail bolts
some kind of bolt extractor should be able to grip the round head of the rail bolts
-Matt
2015 F-250 XLT 6.7L
