Under $100. fuel pressure monitoring - Ford Powerstroke Diesel Forum
Old 02-19-2012, 09:53 AM
I have an Edge Insight CTS, but didn't want to pony up for the expansion harness and goodies ($200) to monitor fuel pressure, so innovation and E-bay to the rescue.
Bought the gauge and sender from a speed shop for $60, picked up the Autometer column insert for $29.95 at Summitt, and Amazon came across with the
12mm X 1.5 X 1/8" pipe adaptor for $7. I really like the look of the setup.
Here are the results:
http://img827.imageshack.us/img827/8...dgarage003.jpg
http://img215.imageshack.us/img215/5...dgarage005.jpg
http://img850.imageshack.us/img850/2...dgarage006.jpg
And finally, my engine one year after the deletes, ELC, and most aesthetically
pleasing oil free boots and couplers from the CCV mod.
http://img853.imageshack.us/img853/8...dgarage007.jpg
Old 02-19-2012, 10:13 AM
Looking good! I'm on the fence with the CTS/expansion fiasco, as shelling out $300 just to get my fuel pressure and EGTs monitored is friggen ridiculous. Seems like a good solution.
Old 02-19-2012, 10:37 AM
I'm still looking for viable solutions to EGT, it will be another separate gauge though. EGT isn't something that concerns me as much as fuel pressure, if I'm pulling a load down the interstate and stop at a rest area, I'll lock my doors with the engine idling and shut her down after about 5 minutes. Oh, forgot to mention, I have the key pad on the door, but a second door key would do the trick as well. If she's been pulling hard, a cool down will cover it. I must be doing something right, the turbo is original with 150K miles.
Old 02-19-2012, 10:39 AM
feul pressure is controled by a spring. is it the same at idle and wot? does it need to be monitored constantly or can you just install a guage off the filter and check it when you change the oil at idle. the blue spring came in the mail this week, but i dont plan on forking up the money to monitor it on my cts.
Old 02-19-2012, 10:51 AM
I didn't want to shell the dough out on my CTS as well, I do have the blue spring as well, but with active monitoring I don't have to worry about my HFCM going bad or weak, and taking out my injectors.
Old 02-19-2012, 11:15 AM
Fuel pressure under 45lbs at WOT kills injectors and over 70-75lbs at idle may blow injector o-rings, mine runs 58lbs WOT and 62-64lbs idle.
Yes you need to check it all the time will tell you if you have plugged filters or weak pump.
2 stroker
