oil cooler housing ? - Ford Powerstroke Diesel Forum
Old 02-18-2012, 03:59 PM
hey guys, on my oiler cooler housing the coolant outlet port has a stainless sleeve with an blue o ring that is on the hose barb where the hose is that goes to egr cooler. it came off when i tried to pull hose off and dont think its a good idea to not put a new o ring in sleeve before putting back together but it didnt come in kit. do you guys change that o ring/sleeve when you have it apart? and is it available from ford separately or as a single part?
Old 02-18-2012, 04:06 PM
You need a hose. I'll find the part number and get back to you.
Old 02-18-2012, 04:33 PM
4C4Z-8592-AA
Old 02-18-2012, 04:49 PM
if i leave the sleeve off coolant outlet, the new blue hose that came with kit is to loose on that end. are you guys saying you dont use the stainles sleeve thats on there?
Old 02-18-2012, 04:51 PM
banshee, is that part # a hose? or the sleeve or o ring im referring too?
Old 02-18-2012, 05:08 PM
EGR cooler hose 4C4Z-8592-AA
EGR cooler hose - o-ring 1 3C3Z-9N693-FA
EGR cooler hose - o-ring 2 3C3Z-9N693-EA
Old 02-18-2012, 05:10 PM
Thanks for the part numbers, I got side tracked.
Old 02-18-2012, 05:22 PM
thanks bismic, is the part # for 2 different o rings or is 1 the sleeve, i didnt pull the other half of hose off old egr cooler yet , is there a sleeve and o ring on that end too cause the new hose seemed like it would just clamp on new egr cooler with out sleeve
Old 02-18-2012, 05:26 PM
The sleeve locks it into place. You have to decide if you want to go w/ OEM design or do your own thing w/ hose clamps.
IIRC the part numbers are only the o-rings. To verify that, you can call TousleyFordParts and ask them (or go to your local dealership).
Old 02-18-2012, 05:45 PM
ok ill check mon at local ford dealer thanks for info
