top gun customz 2.5 leveling kit - Ford Powerstroke Diesel Forum
post #1 of 15 Old 02-18-2012, 09:14 AM Thread Starter
dkmhockey155's Avatar
hey all my birthday is next week and my lovely wife told me she's buying me a leveling kit so i was looking at the 2.5 in leveling kit from top gun customz with the bilstein shocks!. was wondering who had them and how they ride how hard are they to install and the big question will i need to get a bigger block in the rear? i have a 06 f250 ccsb fx4 on 305/70/17 34's please give me some info if you have this kit. thanks guys POWERSTROKE'n for life
ps heres the kit http://www.topguncustomz.com/Store/G...view=236898543
dkmhockey155 is offline
post #2 of 15 Old 02-18-2012, 09:30 AM
Mr. Black's Avatar
Quoted: 5 Post(s)
It's all opinions.
You won't be disappointed with the Bilstiens.
I would recommend an F350 block unless you like a nose high look.
I prefer front spacers that bolt to the axle instead of the top of the spring. Mostly for asthetics.
Steve
2006 F350 Lariat, 6.0 PSD CC LB 4X4. 100k miles.
Wix coolant filter, Dynomax Ultraflow exhaust, cat mod, Edge Insight CS/with EGT. Sinister EGR delete, EGR cooler delete, up pipe. Looney Tune via SCT X4. S&B Intake.
Mag-Hytec transmission pan, 08 diff cover.
2" leveling kit. RS9000 Shocks. B&W Turnover Ball/ Companion Hitch. Airlift 5000 airbags.
2012 Heartland 5th wheel. 36' @ 12k pounds.
Mr. Black is offline
post #3 of 15 Old 02-18-2012, 09:52 AM Thread Starter
could u explain more on these spacers?
2006 f250 crew cab short bed FX4
305/70/17 BFG KM2
2.5 leveling kit with scorpion shocks
4 in turbo back MPRB exhaust no cat
sct tuner
POWERMAX TURBO!!!! WHISTLE!!!!
extreme street powermax tune from eric at innovative
post #4 of 15 Old 02-22-2012, 08:29 AM Thread Starter
bump it to the top
305/70/17 BFG KM2
sct tuner
post #5 of 15 Old 02-22-2012, 09:28 AM
hazard's Avatar
You might as well go on ebay spend 20 bucks and buy a set that includes two 2 inch billet alluminum spacers that bolt to the axle and spring sets in stock perch....easy install with normal shop tools, then spend your money on f350 blocks and u bolts (unless you already have a 350). 150 bucks should just about pay for the 350 blocks and u bolts from ford. With just a 2 inch level on the front of my 06 250 ccsb it sits 1 inch high in the front, when I buy my 350 blocks it should sit 3/4 inch higher in the rear which should looks pretty good.
Thanks,
Adam
2006 F-250 6.0L CCSB Lariat 4x4, ARP studs, SCT tunes by innovative diesel, Silverline 4" turbo back exhaust no cat no muffler! Upfitter switches w/high idle mod, Edge Insight monitor w/EGT probe, autometer fuel psi gauge, Zoodad mod with billet plate. Ford Updated fuel psi spring and banjos, RCD egr delete, Ford updated oil cooler and stc fitting, dieselsite cac boots and coolant filter.
1984 Mercedes Benz 300D Turbo Diesel, cold air intake.
"Run Hard, Dream Big"
hazard is offline
post #6 of 15 Old 02-22-2012, 10:59 AM
smokersteve's Avatar
Quoted: 20 Post(s)
That kit only supplies spacers and shocks. With 2.5" of lift, you need other supporting suspension components. 2.5 puts every thing out of alignment. With ONLY SPACERS, you should not get any bigger than 2". If you get more than that, get a kit with more supporting parts. Really nice shocks, are not going to cut it.
13Q Trans Fluid Flush
FICM Testing Videos
smokersteve is offline
post #7 of 15 Old 02-22-2012, 11:08 AM
Wait, are 350s "leveled" already?
08 F350 CCSB Lariat - massaged exhaust, MiniMaxx, AFE Stage 2, Flo-Pro CAC pipe, CCV modded 2" leveling kit. soon to come - EGR delete, sinister intake elbow
Traded in 06 F350 CCLB - 5" diamond eye exhaust, sct (removed before selling), coolant filter, high idle
Zeek is offline
post #8 of 15 Old 02-22-2012, 11:18 AM
Jaybird093's Avatar
No. not from the factory.
________________________
2006 F-350 CCLB Lariat
6.0 Powerstroke
6-Speed Manual
5" MBRP Turbo-Back Strait Pipe, 6" tip
'03 Turbo
6.4 Banjos
BLUE Spring
High-Idle Mod
Zoodad
Amsoiled & Rev-X'ed
DieselSite Coolant Filter w/ Cat ELC
295/65/18 Duratracs
Jaybird093 is offline
post #9 of 15 Old 02-22-2012, 01:29 PM Thread Starter
so whats a kit with all the supporting parts?
305/70/17 BFG KM2
sct tuner
post #10 of 15 Old 02-23-2012, 05:00 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
Just some info on level kits..you must use a adj track bar to recenter the axle as the axle will shift 1"+ with a 2.5" level kit. use of just a drop bracket or spacers will change the steering angles which will introduce bump steer unless you have a equal droped Pitman arm.
You also must add Castor shims or do a 4 link kit to regain your lost Castor from the level kit..its Geometry.
F250 will need a taller rear blocks and Ubolts unless you like the pre-runner look
Longer shocks would be advised over shock extensions..
If you deside on a complete system I would look at Pure performance or a Icon kit, let me know..we are a dealer for both.
Cary
CT Performance, Inc. is offline
