Car Dolly, Trailer or Flat Bed Towing - Ford Powerstroke Diesel Forum
Old 02-18-2012, 06:15 AM
Can i use the car hauler or front wheel dolly from U-Haul to bring my dead truck from DFW Airport to North Central Ford?
Or is the flat bad Tow Services my only option?
Denny
972 841 3278 Cell
Old 02-18-2012, 06:21 AM
War is the answer!
Whats the weight limit. The car dolly I had, had a weight limit.
Old 02-18-2012, 06:26 AM
I don't know that's what i'm trying to figure out, could it go back wheels on the dolly with the steering locked?
D
Old 02-18-2012, 10:22 AM
I dont think the dolly will be wide enough, I had a hard time trying to find one to pull my brothers expedition home. I think the best bet is to find a flat bed or roll back truck to haul it. Check the dimensions out and see if you can find a trailer you could borrow. Good luck with the haul.
Old 02-18-2012, 10:29 AM
Idk if I'd rise a rear wheel dolly. I'd only put the front tires on it, and only if the weight limit is ok. Other than that, I'd just get a flat bed wrecker.
Old 02-19-2012, 07:13 PM
How far do you have to go? You only wanna go so far with the rears on the ground with the tranny in neutral.. if you can get the rear wheels on a dolly you can use your seatbelt to lock the steering wheel and tow it that way. Duallys are hard to fit on a flatbed sometimes especially if they show up with a 19 foot bed.. If you have to go far you could always pull your driveline and put the front wheel dolly but it all depends on what the weight limit on the dolly is. some tow companies wont put a dually on a flat bed and will charge you for a medium duty wrecker.
