Is there different size intake gaskets? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 02-17-2012, 09:40 AM Thread Starter
My mechanic said to me get the long intake gaskets, what the hell is that? Is there a short gasket?
2006 F250
K&N intake
6" Pro comp lift
37x13.50x22's
SCT Custom tunes
Edge Insight W/Pyro
shaved door handles
Blue spring upgrade
EGR welded/deleted
Sinister coolant filter
Guntruck is offline
post #2 of 8 Old 02-17-2012, 06:56 PM Thread Starter
Anyone? I could use the advice.
2006 F250
K&N intake
6" Pro comp lift
37x13.50x22's
SCT Custom tunes
Edge Insight W/Pyro
shaved door handles
Blue spring upgrade
EGR welded/deleted
Guntruck is offline
post #3 of 8 Old 02-17-2012, 07:00 PM
Powerstroke Techie
forddieseldoctor's Avatar
UMM... The intake gaskets are long and skinny. I'm not 100% sure what he's talking about. Here's a pic of the gaskets.
Ford Senior Master Diesel Tech
IF YOU DON'T WANNA STAND BEHIND OUR TROOPS
THEN FEEL FREE TO STAND IN FRONT OF THEM
Meet Double Aught
2000 F250
forddieseldoctor is offline
post #4 of 8 Old 02-17-2012, 07:31 PM
Quoted: 27 Post(s)
They are re-usable too .........
Mark
06 F250CC SB FX4 Lariat;ARP studs;OEM gaskets; Banks exhaust;DynaTrac Ball joints;Coolant filter; High-Idle;RACCCV6000;JimmiJammers;Ravelco;SynchroMax trans case;Fumoto valves;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower270AXP;PowerInverter;Rancho7000's; BPD EGR cooler;One-piece HPOP fitting;BilletWaterPump;SCT w/ Matts SRL;ELC Ultra
bismic is offline
post #5 of 8 Old 02-17-2012, 07:59 PM
Powerstroke Techie
If you're in there and have more than 60,000 on your truck you might as well replace them.
Meet Double Aught
2000 F250
post #6 of 8 Old 02-18-2012, 03:49 AM
Quoted: 27 Post(s)
Ford has quite including them with the gasket kits (even the kit that originally was labelled "intake gasket" kit was relabelled to "gasket kit" without the intake gaskets). Ford sure do appear to be "encouraging" inspection and re-use. I know many techs that re-use them.
As for me, I think like you do and I replaced them when I did the headstids. I agee - they are cheap, but many people are into saving $30 or $40. Most likely the risk is low, the pressure certainly is!
Mark
bismic is offline
post #7 of 8 Old 02-18-2012, 09:59 AM
Powerstroke Techie
But every little pre-turbo exhaust leak and boost leak can add up. If you explain it to the customer like that they will most times agree with you.
Meet Double Aught
2000 F250
post #8 of 8 Old 03-03-2012, 11:43 AM Thread Starter
I'm certainly gonna replace them just didn't know what a shirt gasket was, I'll ask him for some clarity...thanks guys.
2006 F250
K&N intake
6" Pro comp lift
37x13.50x22's
SCT Custom tunes
Edge Insight W/Pyro
shaved door handles
Blue spring upgrade
EGR welded/deleted
Guntruck is offline
