rocker box help
should i or shouldnt i follow this?? this is what came with my heads lable now out of every one on here thats done heads you all should know if theres any truth in this??? it just dont sound right were they say IT WILL WORK PERFECTLY BECAUSE WE RCOMEND IT..... thanks for the help.
THE DEALER RECOMENDS NOT USING ANY BOLTS TO BOLT THE ROCKER BOX TO THE HEAD BECAUSE IT PULLS IMPROPER TORQUE FROM THE HEAD TO THE BLOCK.
IF YOUR HEAD HAS 8 BOLT HOLES FOR THE ROCKER BOX AND OURS ONLY HAS 2 IT WILL WORK PERFECTLY BECAUSE WE RECOMMEND NOT USING ANY ROCKER BOX BOLTS. THE ROCKER BOX IS HELD DOWN BY THE TORQUE OF THE HEAD BOLTS OR STUDS.
WE DO RECOMMEND USING “ARP STUD KIT”.
