Auto to manual locking hubs on an 06
Just curious if anyone with the auto hubs on an 06 has ever swapped these with the factory manual hubs? Would it be as easy as just swapping hubs then you would true manual hubs?I realize I would then have to get out of the truck to lock them and then I could flip the switch to engage 4wd.
There were no manual locking hubs for the 06 model year. The manual hubs that were used (or are available) for earlier year axles won't fit (think they changed for 05). To swap in manual hubs, I have only found one place that makes them, and they are in the $1500 range. That buys a few sets of auto-hubs....
I have also been curious if the factory manual hubs would interchange with the auto hubs.
I would love to get rid of the auto hubs, but don't have the $$ for the Dynatrac conversion! But I keep thinking about it
You are correct, I was half correct.
Don't know what I was thinking...I went through the specs I have for the 06 model year, and there is no mention of the difference between the two axle setups (manual lock/auto lock). You would think that if the stub axles or knuckles were different, there would be a separate listing in the Ford spec sheet. CLICK HERE to download that Ford spec sheet as a pdf file, if you want to check it out. |
One thing to consider is that when you switch to the manual hubs, if you can, you must plug the vacuum line that actuates the auto hubs. If you don't your climate control will be stuck on defrost, which sucks. Also, in my experience, unless you do lots of hardcore off-roading you are better off keeping the auto-hubs. It is rather inconvenient having to stop, loose all your momentum, get out, and lock your hubs everytime you want to cross a little mud puddle or go up a slippery hill in the snow, JMO.
In trying to diagnose my vacuum leak on psn and psa some were telling me my hubs were auto and they were supposed to lock automatically when I switched the in cab esof to 4lo but my hubs have never locked automatically I have always had to get out of the truck and turn the hubs with my hands even before my vacuum leak. So is there a difference or am I confused? Thanks
Do you have manual or auto hubs? manual hubs will say lock and free as the two positions while auto hubs say lock and auto as the to positions.
they say "lock" and "auto". But like I said, before any vacuum leak, I had to manually lock the hubs AFTER i switched the in cab esof switch to 4lo.
Did the hubs work in 4hi ? maybe they are supposed to do that...
