Where to Install Oil Pressure Sensor - Ford Powerstroke Diesel Forum
post #1 of 4 Old 02-16-2012, 08:10 AM Thread Starter
I have just spent the last two hours trying to figure out where to install the engine oil pressure sensor for my new glowshift gauge. I saw that many people are buying the billet filter cap and plugging the sensor into it. I would rather not do that so its not such a pain when going to replace the filter or if I decide to get a oil bypass filtration system installed. From what I read the only place to intall the sensor is where Ford has put its dummy light oil pressure sensor in at.
Ive read so many different threads on how to take use of this port and Im very confused on what fitting I need.
Im sure Ill need to split this port by using a T fitting so that I can plug both the Ford dummy light sensor and aftermarket sensor that I have into this port.
My problem is I dont know what exact fittings I need. Can anyone provide links to all the fitting I will need?
wwholden is offline
post #2 of 4 Old 02-16-2012, 08:12 AM Thread Starter
In this diagram I believe the port that Im referring to is where it shows: Oil pressure switch.
Page 25: Lubrication System
wwholden is offline
post #3 of 4 Old 02-16-2012, 08:31 AM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
Here you go, pictures and fitting sizes.
http://www.amsoil.com/bypassfilters/...6.0/index.aspx
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #4 of 4 Old 02-16-2012, 09:56 AM Thread Starter
Ok that helps out. Anyone know of a good website that sells these fitting at a decent price?
wwholden is offline
