FICM or Injectors? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 01-25-2012, 12:23 PM Thread Starter
ptsk06tank's Avatar
FICM or Injectors?
Here lately my truck has been running rough on start ups, usually after sitting over night. I had a code for the FICM, so I checked it. Putting out 47.7 volts. I cleared the code and has not popped up since. I thought ok maybe its because of the colder weather. Then I noticed it didn't have as much power and the fuel economy was getting worse.
So I bought some Rev X from Vivian to see if it could possibly be a stuck injector (I need to run Rev X anyway). Gonna drive it awhile to see if it gets better.
Also on start ups the CTS will show a voltage reading of 40.0. Then it will go back to 48.0 volts. If it matters I replced the batteries last summer. So I don't think the batteries are bad they show good voltage with a meter.
My question is, could it be possible that the FICM is going bad and I also have a sticking/ bad injector? I'm thinking that it's both. The reason I think this is because maybe a stuck/ bad injector could be putting stress on the FICM making it show a code. Ex. stuck injector putting a load (higher current draw)on the FICM causing a loose/ bad connection or low voltage. Throwing a code.
Thanks
Cory
'06, w/ Modded 62mm 03' turbo , 4in DP w/ 5in MBRP Exhaust, 58V FICM by Vivan @ Q.T., Sinister Delete, SCT Livewire (SRL tune from Matt @ G.H.), CTS Insight, Firestone Rear Air Bags
ptsk06tank is offline
post #2 of 11 Old 01-25-2012, 12:38 PM
A. Are you testing the batteries independently and disconnected from the truck? If not, that's crucial.
B. 40 volts sounds low, even with the glow plugs coming on.
C. I'm much more suspect of the FICM than I am the stuck injector theory.
Brieldo is offline
post #3 of 11 Old 01-26-2012, 03:41 AM Thread Starter
ptsk06tank's Avatar
Yea the voltage on each battery checks good. One is 12.6 and the other is 12.8. I just think its strange that the FICM voltage goes back to normal ranges after the truck warms up. It was showing 38.5 volts this morning. Temp was around 45*F.
Cory
post #4 of 11 Old 01-26-2012, 03:55 AM
diablos30's Avatar
Quoted: 31 Post(s)
its junk, replace it before it ruins injectors.
diablos30 is offline
post #5 of 11 Old 01-26-2012, 03:56 AM
Rhys05's Avatar
Your FICM needs to repaired, if it dips below 45V at any time, then it is on its way out. Mine is rock steady at 48-48.5V all the time after repair at FICMRepair.com. Get it fixed before it DOES hurt your injectors.
2006 SuperCab Short Bed XLT F250 6.0PS, Sinister coolant filter, ScanGauge II, "Blue Spring" FPR upgrade, chrome bull bar, 35" tires, SCT X2 with tunes by Gearhead
Rhys05 is offline
post #6 of 11 Old 01-26-2012, 04:23 AM
The reason it does this is probably because of the inductive heating that it does to the injectors, it is supposed to help with stiction. When is doing this the FICM is under its largest load so the V drops more.
2012 F250 Lariat CCSB FX4, Gooseneck and 5th wheel prep package, H&S Minimaxx, 5" AFE SS straight pipe, EGR delete with factory EGT sensor, 35" Toyo MT's on stock rims, and Bilstein 5160 shocks.
thomaslord84 is offline
post #7 of 11 Old 01-26-2012, 05:17 AM Thread Starter
ptsk06tank's Avatar
Thanks, Should I go with a 48V or 58V FICM?
Cory
post #8 of 11 Old 01-26-2012, 07:48 AM
pizza pig's Avatar
your decision, the only upside to the 58v is slight better cold starting.
BTW get your batteries LOAD tested, dont check their voltage with a multi meter. You need to test the load capacity reading the CCA (cold cranking amps) of the battery, they need to be disconnected and need a special tool to do so.. you can buy a load tester from harbor freight for $25 thats what I did.. well worth the money
Mine read over 13v on both but on a load test only pulled 650cca on batteries rated at 880cca..
your batteries are probably bad which led to damaging the ficm
pizza pig is offline
post #9 of 11 Old 01-26-2012, 09:12 AM
^^^ What they said! The FICM needs to be repaired/replaced and load test the batteries. Both of my batteries showed over 12V on the meter but both failed under load and were replaced.
2005 - Excursion - Eddie Bauer - 4x4
185amp DC Power Engineering alternator
BPD oil cooler and cold weather package
Updated standpipes and dummy plugs
Edge Insight CTS with fuel pressure
No more STC fitting in the HPOP
Updated fuel pressure spring
Updated turbo oil drain
Updated turbo oil feed
Sinister Coolant Filter
BPD 58V FICM
Dual Batteries
Rotella T6
CAT ELC
The best 6.0 advice I've ever seen...
Fishermedic is offline
post #10 of 11 Old 01-26-2012, 09:31 AM
^^^what they both said. the batteries need to be 100%. i suggest ed at ficmrepair.com and then sending it to PHP to have it tuned. a 48v module can still be tuned. a 58v module just costs more. all depends on what u wanna spend
05 F250 FX4 Supercab XLT LB 6.0 Torqshift ESOF, Boss V-Plow, Diamond plate running boards and toolbox, 105gal Diesel Tank 15GPM pump, 130+k Blue Spring Update, Sinister Coolant Filtration Scangauge 2
joe_r_dog is offline
