CAT EC-1 coolant and coolant filter confused - Ford Powerstroke Diesel Forum
Old 01-18-2012, 02:40 PM
Okay so i just brought a 6.0l and getting a little overwhelm my truck is going in for service truck is a 05 6.0l f350 74k miles
1-oil change
2-fuel filters
3-check all other fluids
4- and was think a coolant flush
Old 01-18-2012, 02:41 PM
is the cat ec-1 coolant gold? im very worried as the service manger told me to only use gold fluid
Old 01-18-2012, 02:58 PM
Gold is not CAT EC-1 rated. It is the reason the 6.0 has so many problems. You will have to provide the right coolant for them if they will even do it. There is a lot of information here about the issues with Ford G-05 coolant. I am sure they will chime in here real soon. PGreenSVT, I think is one of the most knowledgeable and has a lot of info attached to his signature for some good reading.
Old 01-18-2012, 02:59 PM
No the CAT EC-1 Rated coolant is not Gold it is RED and i would be worried also if i had Ford do a coolant flush. There flush may take from a 1/2hr to 1hr mine took 12.5hrs big difference.
2 stroker
Old 01-18-2012, 03:02 PM
Send a message via AIM to mustangman02232 Send a message via Yahoo to mustangman02232
of course he does, he just reads a script from ford, and then need job security, but the gold needs to be flushed and replaced or your oil cooler will look like this, I would also ask them to run a test to see what the temp differance between oil and coolant temps are (they should be 15*)
Old 01-18-2012, 03:08 PM
I have a private mechianc that does my work on my trucks how many times should it be flush before putting the red in... im just dont want to make a mistake on these things
Old 01-18-2012, 03:38 PM
OK, 12.5hrs 48 gallons of distilled water 1/2 gallon Restore 1/2 gallon Restore+ 1/4 tank of fuel new Ford t/stat 3 1/2 gallons of Delo ELC coolant. All i can say is my system is clean.
2 stroker
Old 01-18-2012, 03:51 PM
PGreenSVT is a site moderator, in his signature has info for flushing. You can pm him also, for the info. He probably will see this soon and answer anyway.
Old 01-18-2012, 05:32 PM
Yes there is an EC-1 rated yellow colored coolant. It is Rotella Ultra ELC. If you want to avoid the frustration of a discussion of coolant color at a dealer service desk during a warranty claim dispute but want to make a transition to an EC-1 rated coolant then Rotella Ultra ELC provides that opportunity. The only way to distinguish between G-05 and Rotella Ultra ELC would be with test strips for molybdates (Ultra ELC has it, G-05 doesn't...and yes, moly is hands-down, no-contest superior as a cooling system additive).
Jonathan
Old 01-18-2012, 05:58 PM
NOT a Democrat
Green = Go
Yellow = Proceed with caution
Red = Stop
Well, as far as coolant and the 6.0 goes, it is the other way around. Always run red, if you have yellow take care of it (meaning change it every 20k and filter it always, if you are using green just stop now.
Bottom line, the yellow crap destroyed these motors.
