Temp Deltas - Ford Powerstroke Diesel Forum
Old 01-05-2012, 01:55 PM
Temp Deltas
ECT would run 178 to 182. It got to 200 going up hill.EOT would run 190 to 198. top out at 207 going up hill. When i left the house it was 34.On the flats ECT was 179-180. EOT would be 195-199. At a idle for ten minutes they both was the same (178). Truck was pluged in and the temps was around 140 before start up. going down the road it took a bit for the oil temp to catch up with the coolent temp. If the cooler was bad would the temp climb rapidly?
I bet I need a new T/STAT. If I change the stat would it make the oil temp rise also making the cooler say it needs replaced
Old 01-05-2012, 02:10 PM
Let's Run'em
Is it puking when your going up the hill?
Old 01-05-2012, 02:17 PM
I have had this truck for 3 months now have not lost a ounce coolant. I drive 180 miles a day to and from work so i check the vitals every 2 days
Old 01-05-2012, 02:21 PM
Let's Run'em
I don't think your t-stat will mess with the deltas like that, sounds like your EGR is clogged and your oil cooler maybe starting to go.....can't hurt to try to clean your EGR though
Old 01-05-2012, 02:36 PM
What is the right way to test this?
Old 01-05-2012, 03:02 PM
your thermostat is bad. replace it and then re-check your delta's
Old 01-05-2012, 05:16 PM
Im not going to worry about it. I just ordered a new oil cooler and egr kit. I want the piece off mind that the SOB won't plug up when I'm in the middle of nowhere
Old 01-05-2012, 09:10 PM
Do the coolant flush while you are at it and replace your tstat while you are in there.
