DieselSite Coolant Filter - Ford Powerstroke Diesel Forum
Old 01-04-2012, 11:24 PM
Found this by accident when changing filter. Coolant filter supply hose rubbing against the intercooler charge pipe. You can see in the pic the shinny spot on the charge pipe with some black rubber material from the hose around it. Wire tied the hose up for now, 2nd pic. It started making a pretty good hole in just a few thousand miles, glad I caught it before it became an issue.
After:
Old 01-05-2012, 03:27 AM
Thank you. I will check mine at the end of the day.
Old 01-05-2012, 04:31 AM
I did that the day I installed mine cause I read about people having that problem
Old 01-05-2012, 05:42 PM
After:
I had the same problem - but things are even tighter as I have the dual alternators. Removed the inlet valve, and installed two street 90s into the filter head to turn the inlet line up (toward the sky) and then over (toward the vacuum pump). Also makes changing the coolant filters easier
Old 01-05-2012, 06:34 PM
Great idea!! Im bound to the parts store. Wife loves it. Ouch! <hitting me as I type>
Old 01-05-2012, 06:37 PM
I hear ya! Not sure what's more dangerous - these trucks or this forum
Old 01-05-2012, 06:42 PM
we need someone to post up 6.0 common wear spots for a sticky... Oops better check if there is one <gulp>
I found the vent hose from the (i think) EGR cooler rubbing aginst the intercooler boot clamp screw
Again tied it up untill I had time to rotate the clamp out of the way. The previous owner must have set this trap.
Old 01-05-2012, 06:48 PM
To my health or wallet?? I didnt know anything was wrong with my truck until this forum....
Hummmm...happy reliable truck, empty walet and POed woman. Well, #2 and 3 were the same before truck, i'de say things are looking up!!
Old 01-06-2012, 07:37 PM
I found the vent hose from the (i think) EGR cooler rubbing against the intercooler boot clamp screw
Funny you mention this rub location. Noticed it on mine last weekend and covered the hose with a piece of 3/4" x 20" long black corrugated electrical loom. All better now
Old 01-06-2012, 07:40 PM
Both
Sometimes ignorance is bliss
