Anything else while replacing injectors? - Ford Powerstroke Diesel Forum
Old 01-04-2012, 07:05 PM
I have a bad injector so I decided to just replace them with 190cc injectors w/ 75% nozzles from Warren Diesel and I'll be putting an Airdog DF-165 on it while I'm at it. The oil cooler has been replaced, EGR deleted and head studs put in along with new heads from Ford. Is there anything else I should look into replacing or checking while I have the engine apart? Standpipes? Anything? Thanks!
Old 01-04-2012, 07:31 PM
Glow plugs wouldn't be a bad idea.
Old 01-04-2012, 07:43 PM
Glowplugs, standpipes and dummy plugs. Also the STC fitting upgrade wouldn't be a bad idea while it's apart.
Dik
Old 01-04-2012, 08:08 PM
Correct me if I'm wrong but I didn't think the '03's had dummy plugs and I thought it was after 2005 or so that they had issues with the STC fittings on the HPOP?
Old 01-04-2012, 08:17 PM
Doh!!! Didn't even look at the year of your truck.
Dik
Old 01-05-2012, 04:10 AM
Feedback Score: 5 reviews
hpop, icp or ipr sensors depending on how they are doing, or what your gauges say
Old 01-05-2012, 06:56 AM
What voltages should I be getting on the ICP and IPR sensors? Is there any way to check the HPOP without hooking up a gauge?
Old 01-05-2012, 06:58 PM
And when they did the studs, heads, EGR delete, and oil cooler, they also replaced the ICP sensor, oil cooler screen, MAP sensor, and oil pressure sending unit.
