Very Rough Cold Starts. Injector Sticktion, Glow Plugs Or Other? - Ford Powerstroke Diesel Forum
Old 01-03-2012, 05:59 PM
I have a 2005 6.0 and it will start up very rough like only a couple of cyclinders are firing to keep it running. It usually clears up after about a minute and may run a little rough till I get out of the subdivision.
I'm running the T5 Rotella 10W-30 but it's due an oil change. Does this problem sound like injector sticition or maybe some glow plugs out? I have not seen any codes pop up and the truck runs fine after it's warm. I don't know if my flash has the inductive heating, which I have read of some people claiming that resolved their similar problems. I have the VXCF4 stratagy code, believe maybe the VXCF7 & 9 were the inductive heating flashes but thought they were bad about causing FICM failures?
Any recommendations to resolve this issue or is it just a typical thing for a diesel in cold weather?
Old 04-28-2013, 07:23 AM
Mine is doing the same sort of thing. I had codes for cyl 8 glowplugs after I installed Looney. I changed out all the glow plugs and the wiring harnesses, but still have the same sort of rough start/miss/smoke on start up. No more codes but still crappy starts.
What was the result of yours?
Old 04-28-2013, 07:29 AM
Powerstroke Techie
Feedback Score: 3 reviews
it's your injectors. Either get a ficm strategy that has an inductive heat program or plan on replacing them. The inductive heat really does work, I've switched to a non-heat strategy and instantly I knew nearly all of my injectors have stiction.
Once you've got 3 or more giving you problems you might as well do them all
Old 04-28-2013, 08:43 AM
Mines doing the exact same thing, Where can i get a "FICM Strategy w/ inductive heating"? Sorry for my noobness.
Tom
Old 04-28-2013, 10:16 AM
that was my next question too!
Old 04-28-2013, 10:39 AM
Lol glad I'm not the only one!!!
Tom
Old 04-29-2013, 12:52 PM
So I looked up the code that with my Livewire and I have the VXCF9DA already. So I guess I am looking at new injectors soon. Crap.
