Price on an 03 6.0 excursion 4x4... - Ford Powerstroke Diesel Forum
Old 01-03-2012, 12:45 PM
Hello everyone, I am looking at a white and tan 2003 excursion 4x4 Eddie Bauer with pretty much all the options (backup camera, dvd, etc...) Has sct, exhaust, and intake as well. Only thing im worried about is its never had any work on head studs and has 145k miles. I can probably pick it up for $14. Does that sound like a good deal? Not real sure what the excursions go for.
Thanks in advance.
-Clayton
Old 01-03-2012, 01:46 PM
well man we just got an 04 excursion eddie bauer, it had 103K on the clock and we picked it up for 21 grand.. I noticed a huge price jump going from an 02-03 to a 04-05.. ours is super clean and it was well worth it.
Old 01-03-2012, 05:32 PM
From the reading I've done the early build 03's are the ones to stay away from.
Having said that if you did your research, brought a monitor on the test drive and everything checked out $14k is a good price, just know what you're getting into.
When we were shopping for ours we liked the look of the 05 better and the 03's had the most negative press so when I started looking I looked for an 05. Would I steer clear of an 03 now that I've learned a little? Straight up NO... I've learned enough to realize that there are products out there to make any 6.0 bulletproof. If you can turn a wrench (or want to learn how) for $14 you could put $10k into it and come out with a great bulletproof truck. At $21 for an 05, when you put $10k into it you have a more expensive, great bulletproof truck!
Regarding the one you're looking at... head studs are not the issue with the 6.0. The issue is maintenance, oil changes and more specifically coolant. If the coolant is neglected it clogs the oil cooler. The clogged oil cooler overheats the EGR cooler. The overheated EGR cooler ruptures and you get coolant into the cylinders. The coolant in the cylinders increases the pressure in the heads. The increased pressure stretches the head bolts. The stretched bolts blow the head gaskets. Or something close to that!
Old 01-04-2012, 08:46 PM
Thanks for the great info guys. I am going to look at it Friday again and will hopefully be buying it! I'll post some pics if I do.
-clay
Old 01-05-2012, 03:01 PM
IU Hoosier Fan
I'd say go for it. I paid $19,500 for mine with 98k miles
I'm also the second owner
