EOT and ECT temp questions - Ford Powerstroke Diesel Forum
post #1 of 3 Old 01-03-2012, 06:23 AM Thread Starter
armyguy's Avatar
ok so Im pretty new to the 6.0. This weekend we took the excursion up to winterpark from colorado springs. The way up we had a nice 50-60mph head wind so the drive sucked... My question is driving my EOT/ECT temps run anywhere between 8-11 degrees different, but on the long uphills really working the truck i was getting 15-17 degree difference but soon as we got onto level ground the temps went back to the 8-11 degree difference.. now the trip home on the same hills without the nice head wind the temps were anywhere between 8-12 degrees. My question is when your really loading the engine the temps go up and hit the 15+ degree difference mark, does this mean my cooler is going bad? we have a full gauges plus the bullydog monitor thing, but we dont run the tune, we just leave it stock..
MINE 03 toyota tacoma 4x4, some total chaos stuff and other bolt ons, 17" of travel all the way around
WORK 05 F450 with a Century Auto grip wheel lift. Great REPO truck. EGR Delete, livewire tuning, 270K miles and going strong.
WORK2011 F550 flatbed, stock for now 55k Miles( gone thing was a POS)
WORK 08 RAM 5500, Snatch Truck, Few goodies to push 450 hp and actually get 17 mpg on the hwy
WORK 01 F550 4x4, jerrdan HPL35 wrecker bed, 278K, stock
armyguy is offline
post #2 of 3 Old 01-03-2012, 06:51 AM
Suck, Squish, Bang, Blow!
dfuzz78's Avatar
Temp deltas will change with the terrain. The only way to truely know is to drive it on level road, at 65mph, for 30 minutes. If you see those high temp deltas (10-15 degrees) during that test, then there is a good chance your cooler is clogged. So go find a flat strech of road and test it out. Good Luck!
Denis "Lt. Sled"
2006 F-350 Crew Cab Long Bed Dark Shadow Gray
462hp / 927ft-lbs Corrected
ARP Head Studs, NUC Motorsports Oil Bypass, CFM+ Intake Elbow, Wicked Wheel 2
Bullet Proof Diesel FICM w/Atlas 40, SCT SF3 w/SPD by TSD! Grover Fire Truck Horns
Cab Light Mod, Blue Spring Mod, Zoodad Mod, High Idle Mod, Lost EGR Mod
dfuzz78 is offline
post #3 of 3 Old 01-03-2012, 06:56 AM Thread Starter
armyguy's Avatar
well thats good news, the last part of the drive into colorado springs is pretty flat and we ran between 65-70 mph for a good 45 min and the temps stayed between 8-11 degrees.. i was just a little nervous when the temps in the hills started getting 15+ degrees.. It was also anywhere between 14 and -2 depending on where we were in the mountains so maybe that had something to do with the big temp difference..
armyguy is offline
