Winter Oil - Ford Powerstroke Diesel Forum
post #1 of 11 Old 01-02-2012, 02:38 PM Thread Starter
gendronk's Avatar
Winter Oil
Hey guys i live on the canadian border in michigan so it tends to get pretty cold. Anyway i work 12 hour night shifts and my truck doesnt start verygood in the mornings and it will not start using the remote. ford said to switch oil to 10w30 but i was wondering what you guys run and what is the thinist possible oil i can run thanks
gendronk is offline
post #2 of 11 Old 01-02-2012, 02:57 PM
There's tons of threads here on oil. Not only on oil, but threads on Rev-X as well which may help you out. I also live in Canada and I can tell you that I just changed my oil for the first time in my truck and used Valvoline Premium Blue Extreme 5w-40. It's an awesome oil, about 1000kms in so far. You can get this at a TSC in Canada or make a trip to the States to grab it up cheaper.
tonwe is offline
post #3 of 11 Old 01-02-2012, 03:35 PM
mustangman02232's Avatar
Send a message via AIM to mustangman02232 Send a message via Yahoo to mustangman02232
test your batteries and ficm. 540 syn helps a lot to.
2009 F350 CCSB Lariat 5.4
fisher MM2, 20% tint, leveled
2003 mustang cobra vert
SLP LM1, CAI, diablow tuner
2004 F350 reg cab 4x4 6.0 (SOLD)
exhaust/tune/deleted, dieselsite coolant filter, CAT ELC, blue spring, fisher MM2,
13.9 @95 mph
2002 Mustang 3.8 auto vert boltons (SOLD)
90 F350 RCLB IDI (SOLD)
mustangman02232 is offline
post #4 of 11 Old 01-02-2012, 04:42 PM
Quoted: 50 Post(s)
Another vote for 5w40 synthetic oil. I use Mobil 1, but there are many other good oils of the same weight. That plus a dose of Rev-X will do wonders for your injectors this winter...
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDC Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
post #5 of 11 Old 01-02-2012, 04:44 PM
I had a look around, but Mobil 1 was just way to pricey on the Northern side of the border. and much harder to find. I was able to get the Premium Blue Extreme locally at my TSC.
tonwe is offline
post #6 of 11 Old 01-02-2012, 06:04 PM
I use the rotella t6. If you have a lot of trouble starting try some Rev-x as well, and like said before check your ficm
2013 Harley Davidson Street Glide, Midnight Pearl
Vance and Hines Big radius pipes
Power Commander V
Arlen Ness air cleaner
2005 F-250 SCSB Lariat FX4.
ARP Head Studs
EGR Delete
SCT X3 with IDP tunes.
Edge Insight CS w/ EGT probe
4" MBRP turbo back
Quick Tricks 58V FICM
cyclonestroker is offline
post #7 of 11 Old 01-02-2012, 06:15 PM
Changed my truck over too Rotella T6 5-40 a couple months ago and cold starting is way better now.
05 CC DRW
4" t/b Magnaflow
Edge Evolution
nhra6002 is offline
post #8 of 11 Old 01-02-2012, 07:09 PM
Quoted: 50 Post(s)
Nothing wrong with Premium Blue. Its good oil. These trucks love a 5w40 weight synthetic oil.
Icon 2.5 CDC Shocks
Carli Track Bar
Previous:
All the BPD goodies
skanj0 is offline
post #9 of 11 Old 01-03-2012, 05:12 AM
jimmyv13's Avatar
Quoted: 46 Post(s)
Feedback Score: 3 reviews
Send a message via AIM to jimmyv13 Send a message via Yahoo to jimmyv13
I am another T6 user. This is my first winter with this truck so I have no prior experience, but I read nothing but rave reviews about going 5w40 full synthetic. My truck had a stiction issue when I bought it and 2 doses of Rev-X later, it's running quite well.
2005 F250 CCSB Lariat FX4
4" MBRP Turbo Back*Sinister Coolant Filter*SRL+*'10 Tailgate*Dicad EGR delete*Premium EdFICM*Powerslot Rotors*Hawk Pads*Riffraff boots*DIY CCV*ARP's*'10 Tails*N-FAB Steps*'12 Rear Bumper*Dashboss*Pioneer DVD*'08 Trans Pan
*Bullitt y-pipe*'14 PE PF Mirrors*Fox 2.0 IFP*'08 Diff Cover
jimmyv13 is offline
post #10 of 11 Old 01-03-2012, 05:17 AM
X2, the colder it gets the more you'll see problems from a weak FICM and weak batteries, check both before you take out some injectors!
2005 - Excursion - Eddie Bauer - 4x4
185amp DC Power Engineering alternator
BPD oil cooler and cold weather package
Updated standpipes and dummy plugs
Edge Insight CTS with fuel pressure
No more STC fitting in the HPOP
Updated fuel pressure spring
Updated turbo oil drain
Updated turbo oil feed
BPD 58V FICM
Dual Batteries
Rotella T6
CAT ELC
The best 6.0 advice I've ever seen...
Fishermedic is offline
