PLEASE! How do I REALLY improve my fuel economy?? - Ford Powerstroke Diesel Forum
Old 01-02-2012, 09:58 AM
Hi all. I have a 2005 6.0 Excursion. It has what seems to be a 10" lift with 37" tires. I have done the head gaskets over, ARP head studs, EGR delete kit. I am averaging about 9.4mpg. I do have an SCT programmer. It wasn't programmed for my truck, it was programmed for an 05 F250 pickup. I do have a Banks Air intake that I have yet installed..... BUT, seriously...there has to be something out there to improve my mileage....WITHOUT REMOVING LIFT. Thank you!
Old 01-02-2012, 10:13 AM
Has the speedo been recalibrated for larger tires?
If not you are getting more miles to a tank than it is registering.
I dont really know why people get less mileage with a lift. I think the recalibration thing is alot of the prob.
Do you live in a cold climate? That will lower your mileage because of warming it up first. If you let it run any amount of time that is zero mpg that gets averaged in.
Getting the correct tunes should improve mpg also.
Old 01-02-2012, 10:29 AM
Agreed, make sure you are calibrated for those tires. Probably your biggest problem.
Old 01-02-2012, 12:39 PM
Several factors to consider when considering mileage with a lift.
1. The truck is up in the air more adding considerable drag. Quite a bit of this comes from turbulence from underneath the truck.
2. When a truck is lifted, bigger (read heavier) wheels and tires are usually added. This issue compounds itself in a few ways. First you have heavier tires to turn. Unsprung weight is a killer for performance and mileage. Secondly, you're reducing the mechanical advantage that the engine/drivetrain has on said tires. The truck has to work harder. Third, you're increasing rolling resistance due to a much larger footprint from the added width and circumference.
All of this adds up quick.
In the OPs case, it also appears that the Ex has custom bumpers on it. There a bunch of added weight right there. I'd imagine that thing weighs in the neighborhood of 10k by itself. That's a bunch of weight to try and get any sort of mileage out of.
Absolutley correct. I'll add that depending on your location, you're going to be getting winter diesel which doesn't give you quite as good of mileage as what is available in the warmer months. I can tell right away when the winter diesel has been stocked in the fuel stations around here. My mileage intantly drops ~2mpg.
Here's a few ideas to improve your mileage.
1. Air up your tires to maximum rated pressure. The tradeoff here might be wearing the tires more in the center and perhaps it might not ride or handle as nicely.
2. Shed as much weight as possible.
3. Get custom SCT tunes. The Xtreme tunes yeild the best mileage if you can keep your foot out of it.
4. Regear the truck. 4.10s or 4.30s would get you back near stock as far as the drivetrains mechanical advantage goes with those 37"s.
5. Check your brakes to make sure you don't have a caliper excessivly dragging.
6. Get an alignment. You'd be amazed how much this can effect mileage. The right toe and castor make a huge difference. Especially on these radius arm suspensions. Somewhere in the neighborhood of +2.5-4*castor is where they like to be.
7. As stated, make sure that speedo is calibrated correctly. That can't be done through tunes. It needs to be set in the ABS computer. (If you regear, this won't be an issue.)
8. You have a lifted truck. People don't usually lift a truck with mileage in mind. Man up and deal with it.
HTH
edit: 9. Make sure your hubs are disengaging.
Old 01-02-2012, 12:41 PM
top 2 ways to keep and improve fuel mpg.
1. Care for the vehicle.
2. Tuning.
Have you re-geared for the bigger tires?
Old 01-02-2012, 02:54 PM
Feedback Score: 3 reviews
That's your ECT? Running with a stuck open thermostat in cold weather can decrease MPG.
Old 01-02-2012, 03:01 PM
I dont mean to hijack but how much difference in mpg's would there be since im running 285/75/16 mudders compared to stock 265/75/16 tires.
Old 01-05-2012, 10:53 AM
Thanks for the tips... much much appreciated. I just bought a 12v Cummins to help with the fuel economy for now... Don't worry though... still love my Powerstroke..
Old 01-05-2012, 02:48 PM
FICM rollback/tuning will help, for the Hijack I lost 2-3 going from 265 rugged trails to 285 firestone muds,and the speedo was corrected. A couple of magazines did some testing, changing from ats to muds of the same size and saw about 1.5mpg loss.
Old 01-11-2012, 10:38 AM
i run 285 75 16 at tires and can still get 20mpg on a stock suspension truck empty. if you want to play with it run it a quart low on oil and use 3/4 quart-26 gal tank, 1 quart 30+ gal tank of 2 stroke oil to a full tank i got almost 2mpg from that alone, you can use standard trans fluid too but doesn't work as good.
