Pulling the t/stat may cut it in half, i did my whole flush without the t/stat used cardboard in front of Rad to build heat so the Restore and Restore+ would work but still took 12.5 hrs and 48 gallons of distilled water but it's clean.
2 stroker
What I did, I stuck a hose in the resevoir.. Opened the fumoto valve and held the truck at like 2k rpms for about 15 minutes.. Before that, I couldn't for the life of me get it clean.
Took me 5 flushes to get clear from the original Ford Gold and 12 to get clear from running around with 1 Gallon of Restore. I did not use VC-9 or Restore+.
I would pull your T-Stat...I did mine 4 times yesterday. Pulled it out when I started, put it back in for the one hour drive, back out and then back in when done. The T-Stat only starts to open at 192...you are not getting full flow through it.
Here is what it looked like after the first 5 flushes to get the Gold out.
Here is what it looked like after I ran it with Restore.
I did not get a picture when done as it was dark, but after 12 flushes it looked as clear as the first pic.
Pull the thermostat and also be sure to have the heat set at high in the cab. Otherwise you wont clean the gunk out of the heater core and lines.
Did you have a coolant filter installed prior to the flushing? I did and it only took me three rounds to get the coolant to run clear.
Also, how's your oil cooler performance? Is it possible that your oil cooler is plugged which is limiting the amount of your cooling system affected by the flushes?
I had my Tstat out the whole time I was flushing. That way, you're always running fluid through the whole system instead of having to heat it up each time. Definitely needed the cardboard to get it up to temp for the chemicals though...
Part of your problem is also in your actions. Instead of just opening the pet****, you need to pull the lower rad hose off. If you don't you aren't getting nearly as much fluid out as your should for each flush. Plus, you are wasting a TON of time by using the pet**** since it is so much slower.
First four are getting the stock stuff out, Then was Cummins Restore, then four flushes, then the Restore+. Then i continued to do more flushes till i got it close to clear, Then i did headstuds and the the internal teardown and build up stuff then filled with water, flushed till clear then went in with CAT ELC. which is the bottom pic.
Also, when I was doing my final flushes, I was using test strips to check ph. It was always low, so I checked the ph of the distilled water and it was low right out of the jug so I finally called it good when it came out clear plus one more flush. Hope I got it all :dunno:
I dunno i drove it around to 194 and rechecked it. I'll watch it over the next few days and refill with 100%.
I guess I could catch a gal. and replace with fresh to get the mix stronger, but it rarely ever freezes much less gets below Zero here in Dallass Texass
Not long enough, 8 weeks passed by quickly, back to the grind tomorrow.
D
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
