Need help with part number - Ford Powerstroke Diesel Forum
Old 01-01-2012, 05:57 PM
Hey guys, I managed to break the fuel line coming off the regulator when doing the blue spring mod. I need to know what the part number is for this hard line that I broke. I know its a return line. Just need the number so I can go the dealer tuesday and say "here, I need xxxx"..
Thanks
Old 01-01-2012, 08:13 PM
i feel thats how mine was twisted, from previous owner. I need that #also.
Old 01-02-2012, 04:40 PM
see if this helps,
2004 Ford F250 Super Duty - 21910493 Fuel lines - engine
Old 01-02-2012, 05:34 PM
Thank you very much... I was actually able to get a hold of a parts department at a local dealership and he gave me what I THOUGHT was the right number, but after looking at the schematic he gave me the wrong one. The correct part number from what I can see is "3C3Z-9C273-AA". Thanks again.
Old 01-02-2012, 08:23 PM
Hey thanks, same # for me by pic
Old 01-03-2012, 06:05 AM
Fuel Line Part Number
You are more than welcome. Glad you found the right part number.
Old 01-04-2012, 04:17 PM
Just a side note for anyone that broke this part. I got the new part with that number and it works 100%.. HOWEVER, the bends in it are somewhat different then the original so 1. I couldn't reinstall that mount for pulling the engine nor could I install the piece that holds the 2 fuel lines together. It does work 100% though.
Old 01-04-2012, 04:22 PM
What year model is your engine? What part # did you install - the 3C3Z-9C273-AA part?
Old 01-04-2012, 04:24 PM
2007 would be the year and Yes that part that you listed is what I installed. It is bent differently, works entirely just couldn't reuse the parts I said.
Old 01-04-2012, 05:26 PM
My parts list shows all of these numbers to be active:
3C3Z-9C273-AA
4C2Z-9C273-AA
5C3Z-9C273-AA
8C3Z-9C273-A (this is quite a bit more in cost than the other 3, so judging by this and the number, it is probably for a 6.4L)
My guess is that the number you got was for an older year model. My list does not give applicable model years unfortunately.
