Rear leaf springs - Ford Powerstroke Diesel Forum
post #1 of 6 Old 01-01-2012, 03:30 PM Thread Starter
MacDougall's Avatar
Rear leaf springs
Well both my rear leaf springs are broken so i need both sides. does any one know of a good place to order them from? i dont do alot of towing but i do some times. from what i have found there are 3 that will fit my truck. one rated for 3000 pounds one for 3300 and one for 4300. which one do i need? and what is the best place to get them. i just need a cheap set, nothing expensive. and every one i find the shipping is as much as the springs them selves. any recomendations?
And the truck is a 2003 F250 4X4 crew cab short bed, with the 6.0l
Mike:
2003 F250 CCSB 4X4, 6.0L powerstroke.
-Sinister coolant filter
-Upgraded blue spring
-5" diamond eye exhaust W/ 6" tip
-Edge CS
-SCT tuner W/ vivians looney tune
MacDougall is offline
post #2 of 6 Old 01-01-2012, 03:38 PM
Quoted: 2 Post(s)
If I were looking for new springs, I would look to get the spring rate that is on the vehicle stock, of one level up. Check with a local body shop to see if they can get you a set cheaper, or a junk yard.
2016 F350 Platinum
ralderman is offline
post #3 of 6 Old 01-01-2012, 03:55 PM
Ray Bennett's Avatar
What did you do to break both sides? Probally the cheapest way to go would be to buy new leafs from a local spring shop. I have a shop near me that only charges about 50 bucks a ply and they will cut them to the exact size you need. Now if your pack is shot then that would not be an option.
Just bought!, 1997 F350 CCLB 5 speed manual, For now the only mod is the 4" straight pipe
2002 extended cab long bed 7.3, 3.5" lift with 37x 12.50 Terra Grapplers on 17" Pro Comps, ts 6 pos chip, 05 grille, DIY 6637 air intake, 4" MBRP exhaust with muffler delete, Built trans with PI TC tugger shift kit and suncoast 5 disk drum, custom made one peice drive shaft, Edge CTS
Ray Bennett is offline
post #4 of 6 Old 01-01-2012, 04:08 PM
bwillis2003's Avatar
Deaver springs if you have bout $600..junkyard for stock springs. Or try looking in the for sale section. Im sure there are plenty of guys on here that have them in the garage after they put and 8" spring for example, when they lifted their truck.
Brandon
2007 F-250 6 point oh
146,000 miles
2.5 inch BDS leveling kit
35" Toyo Open Country A/T
OEM rotors w/ Hawk LTS pads
5 inch custom sidepipe
Edge Insight CTS
SCT X3 w/ Innovative Tunes
ARP headstuds
Bilstein 5100s
Banjo Bolts
NCHornet's CCV Mod
Dieselsite Boots
EGR Delete
FICM fixed by Ed/tuned by PHP
S&B Intake
Dfuser Coolant Filter Kit
2003 F-250 7.3
84,000 miles
SOLD
bwillis2003 is offline
post #5 of 6 Old 01-01-2012, 04:28 PM Thread Starter
MacDougall's Avatar
I do alot of buisness with denver spring and they wanted $230 per side so 460 total, i have found many places on line for $130 a side but then the shipping is another 150 so i was just wondering if any one new of a place to order them on line with free shipping.
And they were broke when i bought the truck not sure how they broke but its the middle two springs on the pack of 4. it was probably over loaded or something to cause them to break. i didnt notice it when i was looking at the truck so.
Mike:
-Edge CS
post #6 of 6 Old 01-01-2012, 04:48 PM
have you checked out tousleyford yet.
2003 F350 6.0L KR CCLB DRW 4x4 auto - bone stock
Edge insight, EAS EGT, turbo timer
Strategys, DAX0-1;TEC0-7
Ford Pilot injection
2005 F250 6.0L XLT CCLB 4x4 auto
Strategys, UPV1;URV0;CYH0-7
PowerMax-KTS 11 blade SP Billet
ARP studs, BPD EGR cooler, 04 uppipe
Banks intercooler system, Airaid Dropin
4" turbo back Magnaflow exhaust w/4" DP
SCT 3015
ID custom tunes
ID Pilot-Injection
ID FICM tune
U235a4 is offline
