Turbo
I took my turbo out and replaced the unison ring. Now all back together won't build boost or anything like that. A friend thinks it is the oil line clogged? Any help
either it's still stuck or possibly your VGT solenoid isn't working. Did you clean the turbo while you had it all apart?
did you plug in the solenoid? any exhaust leaks? can you spin the impeller by hand? |
Agreed. If you didn't seat the up pipe flange correctly on the turbine it will be extremely laggy.
Yea I cleaned all the veins and both housings. I'll check the both mainfoldd tomorrow
I did both exhaust clamps over and seemed to be better but now the truck sputters still it seems like it struggles to get about 2000 rpm. It also kinda shakes when it won't rev up
To get above 2000rpm
Did you plug in the MAF?
Everything is plugged in all hoses are connected that I can see
How much PSI are you getting out of the turbo at WOT?
About 30psi
