Best upgrade? - Ford Powerstroke Diesel Forum
Old 12-31-2011, 09:36 AM
Best upgrade?
I have a 06 F250 with a 6.0 (150,000) miles on it. I've done a cat delete, egr delete and a diablo tuner on it. What would be a good upgrade I could do to it to improve mpg's and performance. Thanks for any input.
Old 12-31-2011, 09:41 AM
Remove the Diablo and go with a custom tuned SCT like this: SCT X3 Custom Innovative Diesel Tuning
youll also want to monitor your temps so i recommend this combo kit: http://stealth-automotive.com/index....roduct_id=1386
Old 12-31-2011, 10:02 AM
Thanks for the quick response. What about a cold air intake? Brand?
Old 12-31-2011, 10:03 AM
there is nothing better for the 6.0L then the stock intake....
Old 01-01-2012, 06:43 PM
You need to get some gauges. Forget everything else you need to monitor that engine.
Old 01-01-2012, 07:19 PM
What brand/type of gauges do you guys reccomend. I assume you mean Fuel pressure, oil temp and oil pressure? I see several upgrades about a blue spring. Benefits? Thanks
Old 01-01-2012, 07:56 PM
I'm a fan of Edge Insight CTS, you'll find many ppl here that are happy with them as well. Has a bigger screen which allows you to monitor more things at one and still be able to read them. I'd also get the expandable version so you can monitor things like EGT's, etc. Well worth the money in my opinion.
Old 01-02-2012, 04:18 AM
Suggest a coolant filter if you don't already have one. Your oil cooler will thank you
Old 01-02-2012, 04:49 AM
x2 that is what I ended up with and am happy with it.
Old 01-02-2012, 05:14 AM
x3 on the CTS
Another happy Insight CTS customer. Definitely the best bang for buck considering the price, future expandability, and number of parameters monitored.
