Once again, EOT/ECT delta after EGR and oil cooler - Ford Powerstroke Diesel Forum
post #1 of 2 Old 12-31-2011, 06:50 AM Thread Starter
surveyingdawg's Avatar
I know this was just discussed but I figured I would start a new thread hoping for more input. I got mine back after doing the EGR delete, new oil cooler and studs and my delta is a steady 7 all the way up to 10. Is this something to be concerned about? The ECT holds steady at 190 it is the EOT that fluctuates.
2016 F350 DRW 4x4
surveyingdawg is offline
post #2 of 2 Old 12-31-2011, 08:00 AM
howell_jd's Avatar
There are many elements that cause fluctuation of the temperature for both ECT and EOT. Coolant temperature is ordinarily more variable than oil as the radiator has a much larger heat transfer surface. If the oil temperature is varying more, I would say that is an indicator of a good oil cooler.
Lower ambient air temperatures may make the ECT EOT delta larger than during moderate ambient air temperatures. Your 7-10 degree delta is within the operational range.
Enjoy your upgrades.
Jonathan
Jonathan D. Howell
Lieutenant Colonel, U.S. Army
2005 EarthRoamer XV-LT (Ford F550)
"Americans Travelling America"
howell_jd is offline
