what is this?
What is the radiator looking thing right behind the fog lights, is it a radiator or another type of cooler?
Should be a tranny cooler
Tranny cooler is bigger than that. Power Steering cooler????
What he said
Power steering cooler. Must be a pre 2006 build date, as trucks built in 2006 and later have it moved upward next to the transmission cooler.
Hmm. Is the power steering fluid red? Cause i might have a leak. the truck warmed up the other day in the drive way and when i moved it there was red fluid in the snow. but i checked it later on a couple of times and i can't find the red fluid leaking or coming from anywhere. Any ideas?
Also could be a fuel leak if you happened to "accidently" put red dyed off-road diesel in your truck... |
I'm pretty sure it's ATF and yeah it is red.
check connector from tranny cooler to bottom of the radiator two connections at the bottom of rad. 1 left and 1 right they leak there all the time ... tighten if loose
i went under the truck today and it is rad fluid i believe. it is coming from a clamp on a hose. i checked the tightness of the clamp and it was tight. so i don't know what to do.
