Yea I have done this before. I DREAD doing it again. Take plenty of your favorite pain killer, mine was Bud Light lol. Make sure there are no kids around because they don't need to hear the words that are going to come out of your mouth. Take degas bottle off, FICM off, take the heat shield off the back of motor it is held on with 2 10mm bolts and one 13 mm bolt. Hope you have small hands and very long arms. The only way that I could get it started back in is from the ground below the truck. That is where the long arms come in at. Make sure you have the right socket because there is no room back there. I forget what size it is its in the 22 - 24mm range though and it has to be deepwell and barely long enough to go over the sensor. Good luck.
