What to look for on gauges???
Just installed boost,trans temp and pyrometer in my truck. What kind of numbers do i want see??
Boost max stock 28lbs i try and stay around 25lbs Trans 140-165* keep under 180-200* Pyro 1350* back off 1250-1300* ok but where did you install the pyro here. 3-Gauge Install Pictures Gauges Needed Fuel pressure under 45lbs at WOT kills injectors ECT-EOT max spread 15* i think at 10* your oil cooler is getting plugged 2 stroker |
Thanks i followed that link from diesel manor for the install. So my pyro is on the back of the drivers side manifold.
Always let it cool down to 350 turn off A/C and in park longest I've had to wait is 2 minutes average wait is 30sec |
I put my pyro probe right in front of #8 cylinder. I actually think that the probe sticks down into the runner for #8. With my Extreme Street tune cruising @ 75, flat ground, my pyro runs about 800-850. WOT the highest I have ever seen is about 1500-1600 but that's @ about 120-130 MPH and you don't need to hold it there long at all.
My boost @ 75 mph usually runs about 4-6 PSI. WOT it will get up to 32 PSI right about the 100 MPH mark and usually stays right around there as speed climbs. Trans temp cruising is about 150-160 and climbs a little with a good WOT run, not much though. Towing a 12K load it runs about 165-175. I also have a brand new tranny. This is all with the Extreme street non-studded tune, and mods in sig. |
