What is the best way tofind exhaust leaks? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 12-27-2011, 10:28 AM Thread Starter
colinmitchell111's Avatar
Looks like I am tearing this pile apart again. Did an EGR delete Friday, had an small leak at the up pipe to the tubo. I didn't have air tools so I wasn't going through the torture of trying to mess with that clamp with a ratchet. Took it to my my buddies house Saturday and we bent one of the tabs on the v band clamp. Yesterday I got a new clamp from the dealer and we swapped them out last night, witch is a pain in the rear with the turbo and up pipe connected. After using a ratchet strap and losening the up pipe bolts we got it lined up and cranked it down. Started the truck up and the same hiss. Before I could put my hand over the turbo and feel air gushing out now nothing around the turbo. Its bad enough I have to drive with my windows down or I will puke. I'm guessing I cracked the up pipe. What is the best method of finding the leak? I am probably going to have to take the whole thing back apart anyways. The coolant pipe on my EGR delete has a steady drip of coolant leaking. Really pisses me off.
04 F250 SC SB auto 4x4
5" Diamond Eye TB
High idle switch
Zoodad
EGR delete
Sinister coolant filter kit
Upgraded blue FPR spring
CCV Dump
Warn locking hubs
SCT with Looney
colinmitchell111 is offline
post #2 of 10 Old 12-27-2011, 12:39 PM
howell_jd's Avatar
Spray bottle of soapy water.
Jonathan
Jonathan D. Howell
Lieutenant Colonel, U.S. Army
2005 EarthRoamer XV-LT (Ford F550)
"Americans Travelling America"
howell_jd is offline
post #3 of 10 Old 12-27-2011, 01:45 PM Thread Starter
Jonathan
So do it just after a cold start? Wouldn't it just evaporate if the motor it hot?
5" Diamond Eye TB
High idle switch
Zoodad
EGR delete
CCV Dump
Warn locking hubs
SCT with Looney
post #4 of 10 Old 12-27-2011, 01:53 PM
scha0786's Avatar
Quoted: 19 Post(s)
you most likely cracked the flex joints on the uppipes. let er cool down then have someone fire it up while you put your hand around the flex joints. elite diesel makes some nice upgraded ones. in order to replace youll have to yank the turbo again, i think. next time loosen the connections at the manifolds and hand set the up pipe at the turbo and tighten the clamp. then go underneath and tighten up the manifolds. ratchet straps break things.
04' F-250 6.0L
AFE Stage 2 intake
Liberator EGR delete kit
4" MBRP Turbo back (straight piped) WHISTLE
Quad Piller Gauge
zoodad mod
Nitto Dura Grapplers
Edge Insight CS
DieselSite Coolant Filtration
Upgraded fuel pressure spring kit
upgraded turbo oil supply tube(solid)
upgraded turbo drain tube
SWAMP's 48V FICM
Rotella ELC
Firestone Ride Rite air bags in rear
draw-tite 30k hide-a-goose kit
scha0786 is offline
post #5 of 10 Old 12-27-2011, 02:13 PM
howell_jd's Avatar
I think you'd see the spray respond vigorously at the site of a leak whether cold or hot - it may evaporate but you still would see the response during the process. This works very well for me on my motorcycle and other small engines as well as on inner tubes. I am certain there is a "smoke test" but sometimes simple is best - and this is exceedingly simple. If you have so much exhaust gas in the cab that you feel sick then perhaps leaning over a running engine isn't the best method to be certain so have a buddy nearby (and absolutely don't seek out a leak indoors even with the exhaust vented...IT'S LEAKING AFTER ALL). The exhaust manifold is also factory-installed without gaskets and may be a source of the leaking if you have removed the exhaust manifolds for any reason (such as adding a pyrometer).
This test is a "point-of-observation" instant response/identification type. You'll see something and know that's where the leak is, or you won't see anything and have to continue searching.
Jonathan
EDIT: scha0786 has identified one of the most-common causes/sources of exhaust leaks of the variety you are experiencing.
Jonathan D. Howell
Last edited by howell_jd; 12-27-2011 at 02:16 PM. Reason: Cracked flex joint...yep, very likely.
post #6 of 10 Old 12-27-2011, 03:40 PM Thread Starter
Thanks guys
5" Diamond Eye TB
High idle switch
Zoodad
EGR delete
CCV Dump
Warn locking hubs
SCT with Looney
post #7 of 10 Old 12-27-2011, 05:06 PM
amdriven2liv's Avatar
Quoted: 4 Post(s)
A stick or heavy wire with a piece of string or the like on the end, and a flash light. when the leak blows the string, there is your leak.
2004 F350 6.0L CC LB 4x4 King Ranch
amdriven2liv is offline
post #8 of 10 Old 12-27-2011, 05:13 PM
Glow Plugs Only
dee004's Avatar
Hmmm sounds simple enough. Gotta remember that one.
05 F250 CCSB 4X4, 05 VW TDI
4"Banks Turbo Back, ARP Studs & OEM Gaskets,
Coolant Filter, Blue spring, Zoodad
Bypass Oil Filter, Kitty By By, Standpipes dummy plugs
BPD oil cooler, EGR Delete, CCV Mod, BPD Oil Cooler, SCT SF3
dee004 is offline
post #9 of 10 Old 12-27-2011, 05:23 PM
Ive heard of using a small hose like a vacuum hose one end close to your ear and the other end to probe for the leak (like a stethoscope). Never tried it myself, but am willing to use when needed. Good luck
Don
SPORTEXP is offline
post #10 of 10 Old 12-27-2011, 05:33 PM
Well I find leaks with a smoke machine. Not a fancy one. one that you would use for Halloween I just rigged up a hose on it shove it in the exshaust and plug off the end and just look for the leak.
this is wallie (grey truck)04 ccsb 6.0 4x4 f250 8 inch lift 38s edge insight cts,sct sf3,egr delete,cat delete,warren 175s,arp studs,oem head gaskets , stock turbo .s&b intake,4" mbrp straight pipe. (Red truck) this is Eva 01 ccsb 4x4 f250 5.4 6 inch lift 33" tires super turd lol
92f150300six is offline
