Coolant Filter Tee position - Ford Powerstroke Diesel Forum
Old 12-26-2011, 09:56 PM
After I had the Semi Bullet Proofing done it was recommended by the shop that I reinstall the coolant filter since I had removed it to make way for a crank case vent kit. I went ahead and Reinstalled it on the passenger side frame rail. I have the coolant supply Tee pointing up vertical but I've seen install pictures with the Tee pointing sideways or down. How important is the Tee placement as far as debris flow to the filter?
Old 12-27-2011, 09:13 AM
bumping for response
Old 12-27-2011, 09:28 AM
I did it this way
Old 12-27-2011, 09:42 AM
Thanks, I'm gonna roll my Tee over to the side like your pic. My hose run is all down hill from the Tee to the frame rail so maybe gravity will assist in moving the sand/solids to the filter and keeping them there. Thanks
