Got Semi Bullet proofed
Truck has been needing turbo work for over a year so I finally did something about it. We started with full diagnostics including injector exam.
EGR cooler had very small leak which had allowed some rust build up inside turbo creating sluggish operation and overboost, insides had no pitting so they anti siezed and reassembled. Oil/water delta was 13 degrees so replaced oil cooler with newer OEM also replaced cracked EGR cooler with Bullet Proof cooler. Replaced oil screen with new steel (old one not torn). Replaced stand pipe. Injector test showed a nice flat graph. Truck is running like new again with quick spool up and boost holds right at 24lbs in stock tune. |
Congrats on getting it done. Did you have any problems or was it as smooth as you were expecting?
Once I said yes to the estimate it went smooth as silk.
LOL!
I didn't realize that you had a shop perform the work.
how much it set you back if you dont mind me asking.. im thinking im about to have to replace my oil cooler and possibly a new egr or delete it all together
a egr delete is around 150 bucks, definatly delete so you wont have to worry again and a new oil cooler from ford is around 200.
tousley ford has oil coolers for 215 last time i checked
thanks.. looks like ill be doing this soon
