My results from Gold Crap Coolant Flush - Ford Powerstroke Diesel Forum
Old 12-26-2011, 07:00 PM
1st off thanks to all that assisted in this transition to CAT Coolant.
Purchased scan gauge II to verify puking 11 - 15 deg differential.
Had Ford Tech Buddy replace oil cooler and flush with Ford VC-9 reported a bunch of black flakes that mashed to the touch.
Got it home removed lower radiator hose and installed Fumoto valves drained and got this....
Flushed once with 1/2 gallon of Restore and got this.....
Flushed again and got this...
Flushed twice with Restore + and got a lot of milky fluid first time, a whole lot less second time and final flush with 4 Gal Dist. water until clear.
Removed the Starter to install Pass. Valve PIA upper bolt requires 1/2" socket and mini 2 1/2" long handle ratchet with 6" extension.
3/8" ID Clear hose from Lowes makes draining engine a no mess process.
I captured almost 1/3 Cup of sand and metallic flakes
Installed Sinister external Coolant Filter so it will be interesting to see what it captures now.
Refilled with 3 Gal CAT Coolant & 2 Gal Dist. Water.
Running 193 and 195
Again, thanks to all and whomever feels they don't need this should just look at the pics.
Denny N Dallas
Old 12-26-2011, 07:49 PM
Man you had a lot of stuff come out. My truck runs 188 and 190
Old 12-26-2011, 07:57 PM
That's incredible. I'm actually lined up to do mine tomorrow and I hope I don't get this much debris out of mine!
Old 12-26-2011, 08:00 PM
wow mine never runs 188/190, mine is 188/192 normal and 186/192 when it is below 35* outside.
Old 12-27-2011, 02:04 AM
Thank God! I never saw that stuff when I flushed my truck, I've changed my coolant filters every 5000 miles for 15,000 miles now........no crud. I did get a slimy, snotty, substance when I first flushed with Restore, that was it.
John
Old 12-27-2011, 03:33 AM
how is your oil cooler after all that...
Old 12-27-2011, 03:56 AM
That was a lot of stuff in there.
Old 12-27-2011, 04:16 AM
Almostdunfukinwidit
So you did that after the new oil cooler install or before?
Old 12-27-2011, 03:53 PM
lpx lpx is offline
what were your temps before the flush?
Also, how many miles on your truck?
Old 12-27-2011, 05:39 PM
06 120K flushed before and after the Ford Oil Cooler install.
Previous 215 H2o 200 ish Oil
Also added REV-X
Now 192 H2o 190 - Oil 195
It also tracks identical up the range from cold.
The best thing to do is remove the lower radiator hose into a rubbermaid tub, no 5 gal. bucket will work.
Denny
