New gauges
I got autometer digital gauges for xmas and i noticed myboost gauge is a boost/vac gauge. Is this the right gauge? It says it only reads to 30 psi what does a 6.0 put out for boost?
I can get over 30 psi easy. You don't need the vacuum part of the gauge so I would return it and get at least a 40-45 psi gauge. You won't see that much boost but you'll know for sure what it is.
Thank you. Out of curiousity what application do you use a boost/vaccum gauge?
If i remember correctly Gas engines use boost vacuum because the IC of them create a vacuum as well, whereas diesel motors dont create a vacuum.
Doug do you push over 30 because of the tune? and the 03 turbo can handle it? |
The tunes will allow me to hit 30+ under hard accel. or load. The turbo has held it so far but I don't doit much.
Thanks. I havent started installing yet. I got a trans temp and pyrometer also. Ive installed a pyrometer but not a trans temp. Can i just replace the factory sensor or is there a better way?
the Edge Insight CTS a great tool also. Edge Inisight CTS Lot of guys get the ScanGaugeII harder to setup but easy to install but both work great. ScanGauge - Trip Computer + Digitial Gauges + ScanTools 2 stroker Last edited by 2 stroker; 12-26-2011 at 01:13 PM. |
Gauge Installations at DieselManor- 2003-2007 6.0L Powerstroke |
Thanks i found that site earlier by accident and almost got them done just gotta tap the egt probe tommorrow
