scan gauge II - Ford Powerstroke Diesel Forum
post #1 of 15 Old 12-25-2011, 10:41 AM Thread Starter
scan gauge II
I here alot about scan gauge II is it made by linear logic? I have a CTS to watch EOT & ECT. wondering if scan gauge will moniter oil pressure hear need to have at least 500psi to start. figured would be help full. but don't want something already have .
FamExc is offline
post #2 of 15 Old 12-25-2011, 10:53 AM
It does measure ICP.
Sent from my ADR6400L using AutoGuide.Com Free
2005 F250, Crew Cab, 4x4, Lariat, Stock except Coolant Filter and Scan Gauge.
dg1653 is offline
post #3 of 15 Old 12-25-2011, 11:01 AM
amdriven2liv's Avatar
Quoted: 4 Post(s)
Your CTS already has ICP doesn't it? If not, can you get an update for it?
2004 F350 6.0L CC LB 4x4 King Ranch
amdriven2liv is offline
post #4 of 15 Old 12-25-2011, 11:24 AM
Quoted: 57 Post(s)
Correct. With latest software update from EDGE the CTS will monitor ICP...
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDCV Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Radius Arms
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
post #5 of 15 Old 12-25-2011, 11:30 AM
mustangman02232's Avatar
Send a message via AIM to mustangman02232 Send a message via Yahoo to mustangman02232
Whats the range for the Icp? have mine programmed for it but not sure what it means
2009 F350 CCSB Lariat 5.4
fisher MM2, 20% tint, leveled
2003 mustang cobra vert
SLP LM1, CAI, diablow tuner
2004 F350 reg cab 4x4 6.0 (SOLD)
exhaust/tune/deleted, dieselsite coolant filter, CAT ELC, blue spring, fisher MM2,
13.9 @95 mph
2002 Mustang 3.8 auto vert boltons (SOLD)
90 F350 RCLB IDI (SOLD)
mustangman02232 is offline
post #6 of 15 Old 12-25-2011, 11:37 AM
Quoted: 4 Post(s)
Engine warm and :
KOEO, Low idle, High idle (2500rpms I've been told) Operating range
Inj. Control Press. (ICP / HPOP)
KO=0 LI=625.5 HI=1400-1450 OR=0-4045 (My low idle is 585, some are reporting the same as normal)
ICP Voltage (Volts)
KO=0.2 LI=1.0 HI=1.8 OR=.15-4.7 Volts
IPR Duty Cycle
KO=14.84 LI=24 HI=40.60 OR=0-50 %
post #7 of 15 Old 12-25-2011, 04:27 PM Thread Starter
just finished updating cts not sure if shows pressure? it shows ICP in volts not psi or did before up date. I have a 04 if that matters.
FamExc is offline
post #8 of 15 Old 12-25-2011, 08:14 PM
Quoted: 57 Post(s)
On the CTS you should be able to toggle the ICP output between volts and PSI.
Carli Radius Arms
Carli Track Bar
Previous:
All the BPD goodies
skanj0 is offline
post #9 of 15 Old 12-25-2011, 09:04 PM Thread Starter
Is psi what I should be watching ? I hear it need to be above 500psi to start if its lower is that a sign of leak or bad hpop? what does volts tell?
FamExc is offline
post #10 of 15 Old 12-25-2011, 09:13 PM
Yes 500psi is what I have been told both on here and by several mechs is the minimum for start up. At low idle I run about 640psi and at max have hit 3600ish per the scangauge. This is what I watch for and when my IPR went south I could only build about 330psi. As far as the volts, there was a thread a couple of weeks ago that laid out the voltage and what each meant. Will try to find it.
2004 F250 6.0L CC SWB 4x4 (name's Eleanor)
Straight Piped, Coolant Filter, EGR Delete, Blue Spring'd, Amsoil'd, ELC'd, Rev-x'd, S&B Intake
JumpinJack is offline
