Starter problem - Ford Powerstroke Diesel Forum
post #1 of 2 Old 12-25-2011, 08:38 AM Thread Starter
Beef52751's Avatar
Starter problem
Well, i have been having problems getting my 03 to start. It seems to start when it wants to but not when i want it to. When i first go out to start it the injectors buzz and everything turns on while the glow plugs warm up, when i hit the key nothing happens, no clicking, no cranking, nothing. All the gauges go down and everything shuts off (as it should) until i let off the key. so i was jump starting it and it would fire right up. I replaced both batteries and still have the same problem. any suggestions???
Thanks
Beef
2006 CCSB F-250 King Ranch FX4 6.0
S&B Intake
Zoodad
Fog Light Mod
T6 5W-40
Boost, Pyro, and Fuel Pressure Gauges
Beef52751 is offline
post #2 of 2 Old 12-25-2011, 02:26 PM
sargar's Avatar
It sounds like a bad starter. When it fails to turn over you need to know if you are getting a signal to the starter relay/solenoid. If you are then it is a starter.
Tuned, Deleted, Filtered, Monitored...all the usual stuff.
sargar is offline
