edge insight oil pressure - Ford Powerstroke Diesel Forum
Old 12-24-2011, 02:20 PM
did anyone ever get this to work on the edge insight???
they claim it is a PID but mine don't work. I have not updated in a couple of months though
note my truck is an 04 so knowing my luck this feature is probably only for the 05 and newer
Old 12-24-2011, 02:27 PM
information regurgitator
No 6.0 has an accurate oil pressure sender (factory installed). The one that is on the truck for that useless gauge on the dash is called an oil pressure SWITCH for a reason. It basically turns on the dash gauge to read normal when the switch detects anything over 5psi. It doesn't move the gauge in relation to actual pressures, just on/off.
Old 12-25-2011, 06:03 AM
where is this and how do we access that?
Old 12-25-2011, 06:07 AM
Here is a recent thread with pictures of where this "switch" is at.
where is the oil pressure sensor located?
Old 12-25-2011, 06:21 AM
Powerstroke Techie
There is no way to monitor low oil pressure pressure thru the PCM, because the PCM does not read this in any way. You can monitor high pressure oil pressure, which is known as ICP pressure.
If you want to see low oil pressure pressure you need to rig up your own sending unit or gauge.
If the truck does not have sufficient low oil pressure it will starve the high pressure system out and the truck won't run. Guess this is the reasoning Ford used for not having a variable reading sensor. It would still be nice though. Especially on a 6.4 where they don't use a HEUI injector and it will stay running with low oil pressure.
Old 12-25-2011, 07:10 AM
so does the insight read the ICP?
Old 12-25-2011, 09:20 AM
Powerstroke Techie
Yes, you should be able to see the ICP pid.
Old 12-25-2011, 10:27 AM
Correct. With latest software update from EDGE the CTS will monitor ICP (and also FICMV, amongst other things)...
Old 12-25-2011, 11:44 AM
What about my 03. I havnt been able to get icp but I havnt updated it in a while
Old 12-25-2011, 07:17 PM
what are normal values to read for ICP and I don't think my version has it but I haven't updated for like 4 months now.
