seafoam in the intake tract - Ford Powerstroke Diesel Forum
post #1 of 5 Old 12-24-2011, 02:08 PM Thread Starter
scha0786's Avatar
Quoted: 24 Post(s)
ok, whats your impressions of buying the seafoam that has the long 180 squirty thing meant to go in the air side. I know your not suppose to put seafoam in the oil which I have never done and don't plan to. I put some seafoam in the fuel tank which I've read is ok to do. But my question is how about using the aresol can to squirt it in the intake manifold to clean out the carbon build up in the intake and valves.
Has anyone done this? this shouldn't hurt anything right because it is post turbo and not touching the oil side.
04' F-250 6.0L
AFE Stage 2 intake
Liberator EGR delete kit
MBRP up pipe assembly
4" MBRP Turbo back (straight piped) WHISTLE
zoodad mod
Nitto Dura Grapplers
Edge Insight CS
DieselSite Coolant Filtration
Upgraded fuel pressure spring kit
upgraded turbo oil supply tube(solid)
upgraded turbo drain tube
SWAMP's 48V FICM
Rotella ELC
Firestone Ride Rite air bags in rear
draw-tite 30k hide-a-goose kit
scha0786 is offline
post #2 of 5 Old 12-24-2011, 02:15 PM Thread Starter
scha0786's Avatar
Quoted: 24 Post(s)
ok so I did some research and this sounds like a bad idea, so this is a no go. That stuff has worked wonders on all my 2stroke and 4 stroke toys/vehicles just though the old powersmoke could benefit
04' F-250 6.0L
AFE Stage 2 intake
zoodad mod
Edge Insight CS
SWAMP's 48V FICM
Rotella ELC
scha0786 is offline
post #3 of 5 Old 12-24-2011, 02:59 PM
jesilvas's Avatar
Quoted: 3 Post(s)
I've done it before, nothing happened. But on a compression ignition engine, I'm sure something could still go wrong.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #4 of 5 Old 12-24-2011, 04:04 PM
smokersteve's Avatar
Quoted: 20 Post(s)
To clean the intake, it will be more beneficial to take it to get hot tanked or let it sit in a cleaner/degreaser. I let mine sit in purple power for 4 days and that got it clean.
Seafoam works great for cleaning carbon. I used it to clean the piston on my snow blower. I could literally wipe the carbon build up off the piston.
13Q Trans Fluid Flush
FICM Testing Videos
smokersteve is offline
post #5 of 5 Old 12-25-2011, 06:02 AM Thread Starter
scha0786's Avatar
Quoted: 24 Post(s)
yeah, I read someone called seafoam and asked them if they could use the aresol can on a diesel and they said NO. The reason is because of the nature of the diesel motor, compression ignition.
Yeah I know, I've used it on everything but my truck. it works so good
04' F-250 6.0L
AFE Stage 2 intake
zoodad mod
Edge Insight CS
SWAMP's 48V FICM
Rotella ELC
scha0786 is offline
