Normal EOT range? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 12-24-2011, 12:01 PM Thread Starter
Normal EOT range?
I am beginning to think my tstat is bad, so having a problem assessing the EOT.
So, what would be considered normal EOT cruising at 65, empty, with ambient of around 30*F?
My ECT wont' go above around 184 for longer than a few seconds at a time, which is why I think it is bad. It was replaced this summer when I did a coolant flush/swap.
'06, XLT, F350 FX4, Auto, Ext. Cab Short bed
Diamond Eye Turbo-back 4" exhaust.
CC Mod
Zoodad Mod
ELC swap
Coolant filter
Blue Spring upgrade
beemerbiker5 is offline
post #2 of 8 Old 12-24-2011, 12:06 PM
What is your ECT at normally
06 F350 Traded
alwil is offline
post #3 of 8 Old 12-24-2011, 12:49 PM Thread Starter
ECT runs around 184 or so. I am just trying to figure if my oil cooler is ok, that is why I am wondering what would be considered normal EOT, without using the delta.
CC Mod
Zoodad Mod
ELC swap
Coolant filter
Blue Spring upgrade
post #4 of 8 Old 12-26-2011, 04:00 PM Thread Starter
No one else?
CC Mod
Zoodad Mod
ELC swap
Coolant filter
Blue Spring upgrade
post #5 of 8 Old 12-26-2011, 04:06 PM
My EOT stays around 195 with normal driving.
Sent from my ADR6400L using AutoGuide.Com Free
2005 F250, Crew Cab, 4x4, Lariat, Stock except Coolant Filter and Scan Gauge.
dg1653 is offline
post #6 of 8 Old 12-26-2011, 04:18 PM
caissiel's Avatar
Your stat is bad, you will get much fast heating and better fuel economy with a new one. Your oil cooler will be possibly the same differencial no mather what is the water temperature, because we are talking of diferential through the cooler. I doubt the flow is any diferent in the cooler with cooler water. Mine ranges from 5 to 8 max at 10 and that is towing my trailer in the signiture, with a new cooler and thermostat at 65 MPH. New thermostat coolant temperature normal is at 191/193F
2005, 6.0L, 6 Spd Std, 3.73 Rear End, F250SD, Extended Cab, 4 x 4 Long Bed. 2008 extension mirrors. GPS/TV/DVD/CD/Rear Cam/Radio installed, Max Energy programer by Hypertech, and Fuel Pressure Gauge. ScanGaugeII for 60 plus XGauges, and MPG. ELC Cat EC-1 Coolant, Pull a 39ft 15500Lbs 5th Wheel Camper Trailer. Mileage Avg is 20MPG, and pulling 12.6MPG.
caissiel is offline
post #7 of 8 Old 12-26-2011, 04:49 PM Thread Starter
Kinda what I thought, the delta should be the same regardless of the ect. Even with a bad tstat, then the eot should stay within 10 of it, right?
CC Mod
Zoodad Mod
ELC swap
Coolant filter
Blue Spring upgrade
post #8 of 8 Old 12-26-2011, 05:23 PM
Fox Hunt's Avatar
Quoted: 29 Post(s)
Ya my ect stays around 192-194
Sent from my HTC Hero S using AutoGuide App
2006 F-350 CCSB Lariat
MBRP 4" Exhaust, ARPs, Barder Stage 2 turbo, S&B CAI, TSD SPD, Warren Competition transmission, Edge CTS, Coolant Filter, High Idle Mod, CCV Mod, Zoodad, Newton Leveling kit, Fuel Mavericks 20x9 , Pioneer DVD head-unit, JL Stealthbox and JL Slash 500/1v2 amp
Future Mods:
Injectors and Driven Diesel RR
-Alex
Fox Hunt is online now
