If you've had a transmission problem please read. - Ford Powerstroke Diesel Forum
Old 12-23-2011, 06:55 PM
Some of you have already read my issue in another thread.
Re-Did my Head Gaskets [Pics] + Weird Transmission Issue
Well today it came back, with a vengence.
I was rolling out of a stop, put my foot into it. Spun the tires bad, let off in 2nd just as I let off it hard shifted into 3rd. Tow/Haul starts flashing and the transmission goes into limp mode. (meaning it feels like it starts in 5th gear and only shifts to 6th.)
Pull codes:
P0767 Transmission Solenoid D stuck ON (this is the direct solenoid)
P2703 Transmission Friction Element D Apply Time Range/Performance
I JUST put in a GOGO direct solenoid last week along with 9 qts of SP and new filters.
So I removed the pan and took out the solenoid. No evidence of sticking. Sprayed her down real well with brake clean and blew it off. Put it back in, still doing the same thing.
Keep in mind earlier in the week this exact limp mode issue happened yet there were NO CODES in the computer and after sitting over night the truck shifted fine I was doing great all week! Made a few WOT runs in 4x4 and everything felt PERFECT.
I checked all my wiring connections, looked for corroded wiring, everything is good. This is starting to drive me nuts, I just put 23+ hours into the truck only to have it barely driveable. I would appreciate any input, this is no way to spend Christmas
Old 12-23-2011, 08:03 PM
that sucks, wish I had a great answer for you, I know in the other thread someone suggested checking the fuzes I believe there are two that are associated with the trans. On an older f250 my trans went into limp mode when the speed sensor in the diff, went out I'm not even sure if the 05's had them but it did throw codes also.
if nothing else call this a bump and good luck
Old 12-24-2011, 05:49 AM
War is the answer!
Try putting the oem solenoid back in.
Old 12-24-2011, 10:00 AM
I'm going to trying swapping solenoids now..
Another thing i noticed. Just cold started my truck after sitting all night (25*) and the trans gauge was reading about 1/4 way warm. I want to think there's an issue with the temp sensor but I'm not getting a code for that and doesn't the gauge usually just die?
Old 12-24-2011, 11:09 AM
Powerstroke Techie
Feedback Score: 3 reviews
in all honesty you probably cooked your direct clutch. This isn't all that uncommon on tuned trucks
Old 12-24-2011, 11:12 AM
Hmm. Interesting. I just swapped solenoids and I'm getting the same situation. Only 5th and 6th gears are available. I can't scan it at the moment but I'm assuming its the same codes.
If the direct clutch IS toasted, is driving the truck in limp mode harmful to it? Just for a bit while I get together a rebuild kit and stuff?
Old 12-24-2011, 11:23 AM
sounds like the biggest issue is that you have a heavy right foot,
Old 12-24-2011, 11:24 AM
And another thing that is throwing me off is the fact that it's been intermittent. The tow/haul flashed a week ago, parked it over night then it was fine all week. Can a blown direct clutch make perfect shifts at WOT with a race tune?
Old 12-24-2011, 11:25 AM
I think my gogo solenoid finshed off the direct clutch as well. I have all forward gears tho. Just slams and slips when shifting to the direct clutch. How fuzzy was your magnet in the pan? Does it make a difference if the truck is tuned or not? Hope you figure it out.
Old 12-24-2011, 11:35 AM
There wasn't much material on it at all, I used a screen filter funnel when I put the old fluid back in today after swapping solenoids and there were some particles but nothing severe or out of the ordinary. Then again, I don't know what to look for.
