Turbo? - Ford Powerstroke Diesel Forum
Old 12-23-2011, 03:30 AM
Turbo?
When cranking my truck (cold) in the mid 30's currently. Right before turbo kicks in there's a chirp( squeek)??? Anyone know about this?
Old 12-23-2011, 05:44 AM
Feedback Score: 3 reviews
You can pull of your air intake tube going from the air cleaner to turbo, check for play in the shaft and look for scaring of the compressor wheel blades to the turbo housing. The compressor wheel blades and turbo housing should not touch.
Also check your serpentine belt, tension pulleys,idler pulleys, alternator, A/C, and steering box pulleys/bearings.
Old 12-23-2011, 06:28 AM
my up pipes cracked, it was the most high pitch squeal u could imagine. but only did it on take off, at first then after a while it did it at any where under 2000 rpm, in first gear. Got the upgraded ones from rudysdiesel.com. it got to be very annoying.
Old 12-23-2011, 11:23 AM
Thanks lilpooh I kinda was wanting it to be the turbo!! So I could go ahead and get that new one!
Old 12-23-2011, 11:25 AM
Thanks it only does right when the turbo kicks in though! Right at the same time my exhaust changes sounds
Old 12-23-2011, 11:32 AM
Very interesting. Mine just started squealing. Right when I take off, for like 3 seconds. Might be the up pipes. Thanks for the info.
Old 12-23-2011, 01:30 PM
I have the full sinister egr delete
Old 12-23-2011, 01:32 PM
Got on my truck pretty hard this morning let the ole looney tune work. EGT hit 1300. Cranked this evening no chirp or nothing. I dunno the mysteries of a diesel! Lol
