Do I have Oil in my Exhaust (PICS) - Ford Powerstroke Diesel Forum
post #1 of 25 Old 12-22-2011, 04:09 PM Thread Starter
I was looking under the truck todaty and I noticed oil leaking from somewhere. It looks like its coming out of where the headers meet the block. Does this look right or whats wrong. I also added a picture of the exhaust which looks like its got oil in it.
2006 F250 King Ranch 6.0L - 2.5" Leveling Kit w/ 4" rear blocks, ARP Studs, EGR Delete, 4" TB MBPR Straight Exhaust, SCT Tuner w/ Quick Tricks, Innovative, and Gearhead tuning, Blue Spring Upgrade, Dieselsite Coolant Filter, ScanGuage II, Dyno-Tune EGT guage, High Idle, Custom Wood Steering Wheel, PAC Aux Input, Ipad Mount, 5% Tint all around w/ 50% Windsheild Tint
Timbo126 is offline
post #2 of 25 Old 12-22-2011, 04:14 PM
peterf.'s Avatar
i was changing my oil today and noticed mine is doing the same thing on both sides of the engine but cant tell where its coming from
peterf. is offline
post #3 of 25 Old 12-22-2011, 04:18 PM
Quoted: 48 Post(s)
raw fuel will do that also
is this your first winter with the truck?
drunk on diesel is offline
post #4 of 25 Old 12-22-2011, 04:20 PM Thread Starter
Yeah but it hasn't gotten below 30 degrees yet. My last oil change was 3300 miles ago and I checked my oil leverl and it looked perfect still.
Timbo126 is offline
post #5 of 25 Old 12-22-2011, 04:21 PM
Quoted: 48 Post(s)
are you getting white smoke on start-up?
post #6 of 25 Old 12-22-2011, 04:25 PM Thread Starter
Just a very little bit of smoke but I think its because of the race tune. When I start the truck up cold it doesnt even make a diesel chatter noise. It almost sounds like a gas motor until the engine temps get in to the 70's. So I'm guessing the tune has it running fairly rich on fuel.
Timbo126 is offline
post #7 of 25 Old 12-22-2011, 04:38 PM
Quoted: 48 Post(s)
probably so... white smoke/unburnt fuel will cause exactly what you're seeing. it ends up looking like oil because the inside of the exhaust ports/pipe are coated with soot, so it looks like black oil leaking out. I wouldn't worry too much about it if everything is running well.
do you plug the truck in? do you let it idle to warm it up?
post #8 of 25 Old 12-22-2011, 04:42 PM
f350powerstroke's Avatar
Looks like a bad headgasket to me
2007 f-350
SCT Street tune Innovative Diesel
4 inch straight pipe
Bypass coolant filter, ELC
Edge Insight CS
leveled 2.5
130k miles
Infowars.com
REAL TRUCKS DON'T HAVE SPARK PLUGS!
Are U Aware?
f350powerstroke is offline
post #9 of 25 Old 12-22-2011, 04:47 PM
Quoted: 48 Post(s)
if it's just that one side, I'd agree. if it's both, it seems unlikely that all 8 ports would be evenly coated
post #10 of 25 Old 12-22-2011, 04:59 PM Thread Starter
No I dont plug it in. And yes its on both sides. I also just had the head gaskets replaced with OEM gaskets at my lats oil change which was 3200 miles ago.
Timbo126 is offline
