bad news for my 6.0!!! - Ford Powerstroke Diesel Forum
Old 12-21-2011, 08:24 PM
i took the truck in for studs ,delete,and head gaskets about a week ago , and today i got a phone call telling me one of my cylinders was out of round alittle and that i need a new piston on that same cylinder...the mechanic said he could just have the bad cylinder bored out and sleeved and put the stock piston size back in...will this cause any problems on down the road ? is ths a good option? and will it still be safe for a few performance mods and towing ? thanks alot!
Old 12-22-2011, 05:29 AM
Any way you can get the truck and run!!!! Have seen an awful lot of these 6.0L torn down, even with severe head gasket, oil cooler and egr cooler failure and have NEVER seen out of round... Doesnt mean it couldnt happen, but if it was you would have had low compression, misfires maybe even not running. So whats the back story?
Old 12-22-2011, 07:02 AM
well i got the truck about a month ago and pulled my horse trailer a few times and noticed it was puking alittle,other than that it ran great but it had alittle bit of a knock sometimes, but my mechanic said it was an injector so i told him fix that too and when he tore it down he found the cylinder issues
Old 12-22-2011, 11:28 AM
If it is out of round go ahead and sleeve it. It is that or a new block.
Old 12-22-2011, 12:09 PM
NOT a Democrat
Sleeve it. I had a 351 stroker that ate a wing nut. Took out one slug and the cylinder. I did have problems but only after it was raced, sprayed and then sat for 2 years. There is no way in heck you will run your 6.0 as hard a I ran this 408 Windsor!
Old 12-22-2011, 12:20 PM
Sorry man just not buying the whole out of round thing...
Old 12-22-2011, 01:21 PM
I would as to have it Mic'd with you standing right over him. I would be skeptical.
