T-stat bad? - Ford Powerstroke Diesel Forum
Old 12-21-2011, 09:44 AM
T-stat bad?
Recently I've noticed that my delta has increased. Not so much from the eot increasing but the ect not getting to temp. I'm running between 182 - 186 in town and 186 - 192 highway. Could the t-stat be failed open?
Old 12-21-2011, 09:49 AM
the OEM Ford t-stat is partially open at 182* and fully open at 192*
pretty sure those are the numbers
Old 12-21-2011, 10:56 AM
From what i have see by my coolant flushing and changing out my t/stat yours could be stuck open better than closed. A stock t/stat starts to open at 192.2* and is fully at 219.2* the back side of a stock t/stat is stamped 89/104*C Celsius to Fahrenheit converter | Celsius-Fahrenheit.com When replaceing a t/stat use only Ford 3C3Z-8575-AA Thermostat with housing
2 stroker
Old 12-21-2011, 11:23 AM
How cold is it where you are? My truck was running around 186 cruising @ 65 so I thought that mine was bad, bought a brand new one from Ford and I still run 186 @ 65. That's all with outside temp around 50f. When it's 100+ outside I run around 194 @ 65.
Old 12-21-2011, 01:58 PM
It's been hovering around freezing for the past several days here (central Ontario). If the t-stat is failing does it affect the eot as well or just the ect?
Old 12-21-2011, 02:09 PM
If you have the stock oil cooler your ECT is going to have a rather large effect on EOT. If you have the BPD oil cooler it will still have an effect but not as much.
Old 12-21-2011, 05:17 PM
I believe my t-stat is partially stuck open (have not had time to replace it yet) and i have observed ECT at 60 mph @ 184 degrees and EOT steady at 188. That is with outside ambiant temps of below freezing. In fact when the outside temp is around the freezing mark, i would not see EOT above 190 unless i put my foot in it...
Old 12-21-2011, 06:00 PM
You should be running about 192-196 with a good new thermostat. Between 35-50 degrees outside temp where I am.
Old 12-22-2011, 04:21 AM
I am pretty sure my t-stat failled this weekend, this past weekend towing my 10k fifth wheel in 40* weather my ECT was ~176-179 and E)T was 185~190. I typically have a ~7* delta while towing my camper but was in the 10-11 degree range this weekend. Is it likely that my delta was larger due to the truck not running at temp or is time to flush the system? I checked the fluid and it is all good
Old 12-22-2011, 04:41 AM
It starts to open at 89C and is fully open at 104C...so that is 192F and 219F respectively... Mine was running in the low 180s, I replaced my thermostat and now it is pretty steady at 190F..that was with it cold and rainy, so I would imagine that if it isn't rainy it will be ~192F or so.
