Installing batmowheel - Ford Powerstroke Diesel Forum
Old 12-20-2011, 07:14 AM
Q about installing batmowheel
I have a buddy is installing a batmo on his stock turbo. he wants to know when resembling the exhaust side if it can get messed up. there is the guide pin and the actuator that goes into the
unison ring. Do they only go in one way? Just want to double check before a put it on.
Sent from my HTC Hero S using AutoGuide App
Old 12-20-2011, 05:52 PM
Powerstroke Techie
Feedback Score: 3 reviews
the turbine housing will only go on one way, there is a notch for the center housing/ turbine housing to line up and the unison ring slot has to fit in the VGT cam
it's hard to explain but a lot of times you can see a black carbon mark on the turbine housing from where the vgt cam opening is on the center housing. this is where the unison ring slot would go
Old 12-20-2011, 08:57 PM
Good to know. Thanks for the help
