Can I mix coolants?
Thursday I am going to install a coolant filter kit and upgraded FPR spring. I also have a new thermostat but I might as well wait untill I do a coolant flush for that right if my current one is working fine? I'm not sure what kind of coolant my truck has and I know I will lose some in the filter install process and I will remove the upper hose to get to the FPR a little easier. How much coolant can I expect to lose? I am planning on running this filter durring the winter and doing the restore flush with some elc in the spring. Should I get a gallon of some cat elc and a gallon of distilled water and mix 50/50 and top off or does it have to be the same coolant as whatever is in there now? Thanks.
Unless u want jello in ur cooling system the answer is hell to the no.
So what is the best way of indentifying my current coolant?
Gold looking color -Ford coolant
red /raspberry - cat elc Green / wrong stuff If you drain your fluid into a clean container you can just reuse it. |
Just drain out about 1 gallon or 1 1/2 into a bucket then get a gallon of distilled water you may only need 1/2 gallon to fill so you should be good as long as it do not get down to -25 where you live + if the coolant is a -32 now, the Gold junk is a yellow green in color and 99% of the ELC coolant is Red in color.
2 stroker
My cooling system appears very clean and my EOT/ECT differential is completely normal. So with 82K miles I just drained and refilled with Zerex G-05 coolant although I really wanted to use ELC. I just didn't want to mess with flushing and the real possibility of actually causing the oil cooler to become blocked.
So now I have G-05 (50/50) and some Fleetguard Optimax Pre-Mixed (50/50) ELC in my garage. I'm gonna mix up a half quart of each and see what happens over time. I suppose I'll have to heat it up on occasion to 190 on the old stove in the garage to simulate the engine heat. Perhaps stir it once in a while. Can't really create the 16psi pressure though. |
Ok so if I drain out let's say a gallon and a half out if the radiator will that drain the heater hose so when I cut it, it won't spill everywhere?
2 stroker
You may spill a pint or a qt it's all in how good you are just plan ahead..
2 stroker
If you spill a quart or less, just top off with distilled water. I would drain a few gallons first and then pour that back in when you're done.
No point changing the thermostat until you do the flush, and when you do, switch to a red ELC. |
