6.0 Newbie with EGR question
Hi all, I just picked up my very first powerstroke. It's a super clean 2005 F-250 crew cab lariet. It is completley stock and has no modifications whatsoever. It is running in perfect condition. No issues at all. As a preventive maintenance I want to delete the EGR as many have here on the forum. My question is If I delete my EGR should I do the Coolant flush prior to doing the EGR delete? I am worried because I thought I read somewhere here that if I do the flush more than likely it will clog my Engine oil cooler faster? Or should I just swap out the Ford gold coolant with the ELC. Also, from what i got from the previous owner he said all maintenance was done on schedule and coolant was flushed every 5,000 miles by a local ford dealer so I'm 99% sure it has the fold gold coolant in it. Thanks
It may look/run/sound in perfect condition, but until you know what your ECT/EOT delta is, your driving blind.
You need to monitor/check your ECT/EOT delta, fuel psi, and FICM volts first, before you decide to spend money on deletes. No sense on working on the motor before you know what it may need. This link will give the basics. Things to consider about owning a 6.0L |
Coolant flushed every 5,000??? Listen to the advice above, start with a monitor and coolant filter.
I would still do an EGR delete and coolant flush (because both are known weak spots). Sure it may clog an already stopped up oil cooler (another known weak spot), but at least it will be flushed so you won't clog up the new oil cooler (which are on a 2 month national back order).
But yes, you definitely need gauges to monitor the general health of the truck. |
This is why the OP needs to get a monitor solution first before he rips into the motor. Do it right the first time, check the health of the motor, then fix the issues. |
The reason I said that was that I was going to delete her EGR cooler (it was getting real bad) and flush her coolant system then drive it for a week and do the oil cooler the next weekend. Sure it's more work but it would keep from clogging the new oil cooler. I would definitely flush it now then you can do both projects (egr delete + oil cooler if needed) at once later. But her egr was getting bad and sure enough her oil cooler is toast too so I'm waiting on that to arrive, probably tomorrow and doing the oil cooler this weekend. Now I have no choice but to flush after both are done.
If her egr wasn't so bad I would have flushed first. She actually had green coolant in hers that the previous owner put in there.
He needs to monitor/check the health of the motor first to see which direction he need to go. |
Thanks for all the replies. So I guess first thing I'm doing is buying a edge insight. I also confirmed I do have the ford gold coolant. So should I just leave that coolant in the truck?
Now this will also depend if your thermostat is stuck open, too low of a coolant temp will not give you a true delta reading. |
I don't mean to steal this thread but how do you tell which coolant you have? Also, which monitor is recommended? I don't have much cash to spend but would definitely like to add performance as well, probably later because of the money (unless there is one out there that is actually affordable). Coach
