175s with stock nozles - Ford Powerstroke Diesel Forum
Old 12-13-2011, 01:29 PM
i have seen a few posts about getting warren diesels injectors with stock nozzles for a fraction of the cost of the ones with aftermarket ones.
does or has any body ran these in their truck? what kind of power do they put out compaired to stock or modified. can i put modified nozzles on them down the road or are they set in stone they way they are?
i am interested in buying a set if i read good things. naturaly i will be buying an airdogII to feed them. would i be able to run the 175s with stock turbo or will i need a powermax or mimimum or batmowheel?
Old 12-13-2011, 05:23 PM
bump... any body?
Old 12-13-2011, 10:11 PM
You could run those with a stock turbo. Tuning could help make it more fine tuned so to speak. A batmo on a stock turbo or a powermax ( or a powermax with a batmo) is only going to help you. Some guys are running 190's on 03 turbos so you'd be fine. To me 175's would be the max with anything smaller than a powermax cause I would want it to run as smoke free as possible, but larger is doable.
Old 12-16-2011, 12:01 PM
ok thank you. has any body had any experience with injectors like this?
