Which parts do I need for my year. - Ford Powerstroke Diesel Forum
Old 12-12-2011, 12:48 PM
ppr ppr is offline
This list is from the 6.0 Bulletproof page. Are all these parts used in a 04' F250 bulletproof. Are these all the ford factory parts I need? Do I need Egr gasket if I delete it?
3C3Z-6A642-CA Oil Cooler Kit
3C3Z-6C683-AB HPOP Screen (Included in the Oil Cooler Kit)
4C3Z-9B246-F is the part number I found for the updated STC fitting with the IPR screen and o-rings.
3C3Z-9H529-A IPR SCREEN KIT
3C3Z-9433-BE Intake Gasket Kit (Includes Turbo hardware)
3C3Z-9P455-AB EGR Gaskets
3C3Z-9T517-AG Fuel Pump Regulator Kit
6C3Z-9T515-A Turbo Drain Tube
3C3Z-9T516-A Turbo Oil Feed Line
6.4 BANJO BOLTS (2)-W302472 bolts,
6.4 BANJO WASHERS (4)-W303659
3C3Z-8575-AA Thermostat (complete with housing, o ring)
Old 12-12-2011, 02:10 PM
Feedback Score: 3 reviews
Don't know about the part numbers, but the '04's don't have a STC fitting.
Old 12-12-2011, 03:23 PM
ppr ppr is offline
Do I need EGR gasket if I delete the EGR.
Old 12-12-2011, 04:04 PM
EGR delete kits come with the gasket or o-ring needed to seal where the EGR cooler was. You have the choice if you want to leave the EGR valve in place, or remove the valve and tie/bolt up to the side, just leave the valve plugged in electrically.
